Who listens to headphones on the computer?
0 Members and 1 Guest are viewing this topic. Read 778 times.
bikes and beats
« on: 25 May 2006, 03:13 am »
Okay,
What system do you reccommend?
Basically, I'm looking for a cheap upgrade from just plugging the Grados into the headphone jack of the computer.
Any advice on headphone amps, dacs etc. would be appreciated.
G Georgopoulos
« Reply #1 on: 25 May 2006, 03:22 am »
Hi how youre doin dude
cool
what price range can you afford??
you havent been specific so ill try to give you some general clues
1 not all headphones/earphones will sound the same
2 not all amps are good for that sort of listening
3 if you buy headphones big are better
4 listen before you buy
hope that helps
cheers
philipp
« Reply #2 on: 25 May 2006, 03:31 am »
If you're o.k. with $200, I'd highly recommend the Total Bithead from HeadRoom. It's got a built-in DAC if you run it off of the USB port on your computer and it's got a line-in to run off of any other player. I bought mine a while back when it was $270 -- yup, the price dropped! I use it at work with a pair of Grado SR60s and I'm very happy with it.
bikes and beats
« Reply #3 on: 26 May 2006, 05:56 pm »
That's what I wanted to hear, Philipp!
Folsom
« Reply #4 on: 26 May 2006, 06:30 pm »
I would probably use M-audio's USB Audiophile device. It has an amplifier in it for headphones, and probably a better DAC than the Bithead (I am going to guess it only has a 27015 whatever thing, not a 1543).
That is a guess though.
Val
« Reply #5 on: 27 May 2006, 11:39 am »
Since you have Grados, try to find a used Grado headphone amp; the Chaintech AV-710 sound card is excellent and cheap at less than $30.
