What to put under these speakers ?
0 Members and 1 Guest are viewing this topic. Read 2428 times.
Soundbitten
« on: 12 Apr 2006, 06:26 pm »
What's best for decoupling/vibration control for Dunlavy Alethas ? They are over 100 lbs. each . I have hardwood floors and am worried that ISOL pads ( the rubber ) might mar . the speakers have a 6 sided wooden base . Thanks .
Soundbitten
« Reply #1 on: 13 Apr 2006, 05:41 pm »
Do I need anything other than the present bases they already sit on ?
Bill Baker
    • Musica Bella Audio
« Reply #2 on: 13 Apr 2006, 06:28 pm »
These would work beautifully and bring ot the most that your speakers have to offer.
http://www.responseaudio.com/sistrum.htm
PhilNYC
« Reply #3 on: 13 Apr 2006, 06:33 pm »
Quote from: Response Audio
How would those work with the hexagonal base?
Bill Baker
« Reply #4 on: 13 Apr 2006, 06:40 pm »
 The same they would work under just about any speaker. You are only looking to achive a 3 point configuration. With the adjustments and versitility of the Sistrum Platforms, it would not be hard to get a well balanced 3 point set-up that would also allow for very good balance of the speaker.
 We have used them under the Daedalus DA-1 which is far from square/rectangular.
PhilNYC
« Reply #5 on: 13 Apr 2006, 07:04 pm »
My initial impression is that it would be hard to support a hex-shaped base on 3 points without some serious danger of the speaker tipping if touched.  Thinking about it, maybe it might even be safer than a rectangle... :scratch:  :oops:
kyyuan
« Reply #6 on: 13 Apr 2006, 07:10 pm »
Quote from: PhilNYC
Use 2 of them  :mrgreen: j/k
woodsyi
« Reply #7 on: 13 Apr 2006, 07:26 pm »
Quote from: kyyuan
No, No and No.  There is a mysterious power associated with number three.  Just ask Pythagoras.   :lol:  :lol:  :lol:
I think they would work fine as long as it is big enough for the speakers.
Bill Baker
« Reply #8 on: 13 Apr 2006, 07:44 pm »
 That's rights. Speakers, source components and amplifiers all benefit from a 3 point configuration.
 For less $$ invested, you caould always go with just the Audio Points (still in a 3 point).
pacifico
« Reply #9 on: 13 Apr 2006, 11:26 pm »
This is probrably available at target or sams club; My kid plays on 1/2 inch thick rubber foam. You could cut this to taste and make various thicknesses by gluing layers together. It's an experiment that wouldn't cost you more than $25 bucks. I would reccomend rubber glue to patch layers together. Only problem is one side is black and the other comes in a variety of colors. You can probrably hide it completely under your speaker or even spray paint it black. It's just an idea.
BTW: By my estimates, one thickness will easily support over 200 lbs./sq. ft. without serious deformation.
Bill Baker
« Reply #10 on: 13 Apr 2006, 11:31 pm »
 Oh yes, the play mat sets. I have some of these laying around also. I woudl think they would be a bit to spongy to set speakers on?? I haven't tried so can't say for sure. Besides, my wife would kill me if I cut them up.
 I am a huge fan of brass points myself. I find better results with coupling than using soft materials. The bass is just not refined and there seems to be a loss of focus in the midrange.
 Just my 2 pennies.
pacifico
« Reply #11 on: 13 Apr 2006, 11:43 pm »
My experimental data suggests 200 lbs/ sq ft w/o serious deform. If the speakers weight is uniformly distributed, even less of a problem. It really only becomes an issue if many thicknesses are needed. If the center of gravity becomes too high, they'll tip over.
Soundbitten
« Reply #12 on: 14 Apr 2006, 12:28 pm »
Thanks for all the suggestions . I appreciate it and will consider them all .  :)
