0 Members and 1 Guest are viewing this topic. Read 2985 times.
I use the PR as a clarity control. There will be one amount of putty which gives maximum overall transparency. If you're not sure how much to start with, take all the old putty off and apply about 6" from a reel of Mortite or similar caulking rope putty and glue it to the apex of the PR with hot melt. Then start removing. I usually end up taking off an amount the size of a small green pea.If you Pr's are not vitrified with Elmer's carpenter's glue (the yellow stuff), take them out and paint both sides ...
To remove the passive unscrew the base and then the wood screws holding the PR in. Pop it loose with a flat blade.To compensate for the mass of the dried glue remove a fingernail full of putty from the center of the PR.
Set the mids at 12 o'clock, treble at 12:30, and remove putty a fingernail full at a time, one PR at a time, and it should balance out nicely.
