RF Interference
0 Members and 1 Guest are viewing this topic. Read 1753 times.
Mountain-ear
RF Interference
« on: 28 Mar 2006, 10:40 pm »
Hi.  I've been following this circle for a while.  In fact, I'm now the proud owner of a T-8 with a 260EX on its way (Thanks, Frank!).  You, the knowledgeable fans of AVA, helped make it an easy decision for me.
My issue isn't related to the AVA gear at all.  I decided to get my turntable out of retirement since my T-8 has such a lovely phono section.  Unfortunately, I get radio frequency interference (a problem compounded by the fact that it happens to be Pittsburgh's urban music station -- not my musical preference).
The problem is not in the pre-amp.  No RFI when the turntable is unplugged and no RFI on any device other than the turntable.  If I remove the cartridge from the turntable, no RFI.  In fact, the RFI increases as the tone arm tracks across the record which suggests to me that the arm/cartridge are acting as some kind of antenna.
Short of buying a new turntable (a possibility, but not right now), any suggestions on how to suppress the RFI?  The turntable is a Yamaha YP-D71 (one of Yamaha's best in 1979) with an Audio Technica AT15SS cartridge (again, one of the best in 1979).  I just completed a Grado Longhorn conversion in case the A/T cartridge was the culprit, and the Grado does the same thing.
Thanks for your help.
WEEZ
RF Interference
« Reply #1 on: 28 Mar 2006, 10:57 pm »
The culprit(s) usually relate to shielding or grounding.
If your arm has a grounding wire- make sure it is not loose. Also, check the interconnects for sound connection(s); i.e.- is there a tear or 'break' in the cable allowing RF into the system? Does the noise go away if you relocate the turntable to a different shelf? These are the most common solutions...
Welcome to AC; and congrat's on your new AVA gear!
WEEZ
Mountain-ear
RF Interference
« Reply #2 on: 29 Mar 2006, 03:30 am »
Weez -
You da man!  Checked and cleaned all the connections.  Found one that was questionable and reset it.  Between that and re-routing the cables when setting the table up again, the problem seems to have been eliminated.
Just finished a two hour stroll down memory lane with some classic vinyl...
WEEZ
RF Interference
« Reply #3 on: 30 Mar 2006, 12:38 am »
..glad to hear it was 'relatively simple' to fix. Usually it is, but when the easy stuff doesn't work, it'll drive you nuts.....
 :lol:
Again, welcome to AC....
WEEZ!
