single driver speakers
0 Members and 1 Guest are viewing this topic. Read 16946 times.
mcgsxr
« Reply #60 on: 30 Mar 2006, 05:54 pm »
Interesting thread, started out about how to get started with single drivers, and has turned into the more stereotypical "how to perfect" single drivers discussion!
I use the b200 Visatons in open baffle.  I sit about 8 feet from them, they are about 8 feet apart, and located with the system in a corner, and they are around 2 feet from the slanting back wall behind them.
I listen to things that range from Spacemusic, world, jazz, vocal, small and large scale symphonic, electronica, classic rock, and audiophile - pretty much all but rap and country.
For 100Hz and up, they are perfect.
Not enough bass for me, but plenty of treble, on axis as I listen.
So, I will basically follow the well worn path of adding powered subs, to have a biamped, active system.  I have experimented with several DIY subs so far, but none have been right yet.
I will soon have the opportunity to A/B these DIY speakers against some nice 2 and 3 ways from RAW in Canada - I look forward to listening to these, and discerning how the mids and highs differ - I know that the bass on the RAW speakers will be much better.
So, to date, there is no perfect speaker for me - but also to date, what the b200's do right, outweigh the frustrations of what they do not, and for the $400 I have in them, it is a no brainer to keep using them!
The only way to know, is to listen, and find out!
  • Speakers....What Speakers ?
« Reply #61 on: 31 Mar 2006, 10:40 am »
SET Man :
    I would love to get a pair of DRD 300B, but I don't have money burning a hole in my wallet right now.
    [/list:u]
      ....Buddy....Wellborne is running a
    sale........ 8) [/list:u]
      Hmmm.....I don't have a SET amp.....yet.[/list:u]
    SET Man
    « Reply #62 on: 1 Apr 2006, 08:24 pm »
    Quote from: lonewolfny42
    SET Man :
      [/list:u]
      Chris,
          Yes, I know about the sale but I just don't have $$$. And I think I will put money on something else since I already have SET amps, totally definrent than the DRD but I love them :D
          But... Chris if you are looking for a 300B amps to pair wiht hi-e speaker than do put them on your list, you can't go wrong with them.  :D
      Take care,
      Buddy :thumb:
