I have experimented with 3 transports and 2 types of cables since I've owned the Museatex. I've also had the Museatex modified to be a 'Data 2 by John Wright"
Here's the results:
(pre modification)
Arcam Delta 70 vs. Arcam Alpha 8:
The 70 sounded veiled, less dynamic, but equally smooth and somehow just as tonally accurate... the Alpha was livelier.
(post modification)
Arcam Alpha 8 (with coax) vs. Pioneer DV-444 (with Toslink):
Not much difference, the Pioneer seemed a little more delicate, a tiny bit less harsh in the midrange and maybe a tiny bit smoother. There was a sound quality difference but, it was a flavor difference not a bad/good difference.
(post modification) (last night)
Pioneer DV-444 using DH Labs Toslink cable vs. Illuminati DV-30 coax cable:
The coax cable sounded more accurate tonally, especially midrange. Things sounded more real/true with the coax. Imaging was identical.
So, maybe "Ultralock" which is probably the same as "C-lock" that the Mueseatex uses takes care of jitter but, there is definitely a difference in cables and transports that attach to this DAC. I think all DAC's have some kind of jitter reduction technology....
