Radio tune in to an SB3
0 Members and 1 Guest are viewing this topic. Read 3120 times.
Charles Calkins
« on: 15 Mar 2006, 01:09 am »
My favorite FM station for the past 18 years has been KKSF 103.7. They broadcast on the internet and I've listened to it sometimes when I'm on the computer.
 When I try to enter the URL in radio tune on the slimdevices site nothing happens. On the right side of the window it says empty.
 Anybody know how I can get slimdevices to recognize this station?
                    Cheers
                  Charlie
Rashiki
« Reply #1 on: 15 Mar 2006, 03:34 am »
Charlie,
It looks like the URL is:
http://a1394.l1979744902.c19797.g.lm.akamaistream.net/D/1394/19797/v0001/reflector:44902
It's a Windows Media stream, and it seems to work if I cut & paste the URL into Windows Media Player. My slimserver is running on a Mac, though, and when I tried to connect to it, it seems to have crashed. Maybe since you're running Windows, it'll work better for you.
 -Rob
pugs
« Reply #2 on: 15 Mar 2006, 03:44 am »
Quote from: Rashiki
Charlie,
 -Rob
How did you get the URL?  I want to play the mighty XX 105.7 FM/ 1090 AM on my Squeezebox.  They broadcast on both AM and FM.
Rashiki
« Reply #3 on: 15 Mar 2006, 06:05 am »
Quote from: pugs
Pugs, try this:
http://stream3.12milesout.net/mty1090
I'm not sure if it'll work, but I found it by going to their website, clicking on some links and using "view source".
 -Rob
Charles Calkins
« Reply #4 on: 15 Mar 2006, 01:34 pm »
Nothing works. No matter which URL I enter the slimserver doedn't recognize it.
                        Cheers
                          Charlie
Rashiki
« Reply #5 on: 15 Mar 2006, 02:29 pm »
Charlie,
I got it to work with my squeezebox. The real URL is:
http://a1394.l1979744902.c19797.g.lm.akamaistream.net/D/1394/19797/v0001/reflector:44902?MSWMExt=.asf
The other URL I posted was just a link to this one. Sorry about that.
 -Rob
Rashiki
« Reply #6 on: 15 Mar 2006, 02:33 pm »
Pugs,
This URL worked for your station:
http://stream3.12milesout.net/mty1090?MSWMExt=.asf
 -Rob
Charles Calkins
« Reply #7 on: 15 Mar 2006, 03:05 pm »
Rob:
 That works as far as getting slimserver to recognize it but when I try the SB3 it says "Can't connect"
                        Cheers
                       Charlie
Rashiki
« Reply #8 on: 15 Mar 2006, 03:10 pm »
Quote from: Charles Calkins
Rob:
                        Cheers
                       Charlie
Well, Charlie, don't give up. I had my SB3 playing your favorite radio station this morning, so I know it's possible.
How did you enter the URL? I just went to the "Radio Tune-in" option on the main slimserver webpage and cut & paste the URL.
 -Rob
Charles Calkins
« Reply #9 on: 15 Mar 2006, 03:22 pm »
Rob:
 The slimserver and the SB3 recognize the URL because both screens say the URL. The SB3 says "Now playing" and shows the URL. But no audio. I went to radio tune in and entered all the numbers you gave me. Is there something else I have to do?
                 Cheers
                Charlie
Rashiki
« Reply #10 on: 15 Mar 2006, 04:09 pm »
Charlie, try pressing the "Play" button on your SB remote control a few times, and then give it a minute. It sometimes takes a minute or two before the SB buffers enough data to start playing.
 -Rob
pugs
« Reply #11 on: 15 Mar 2006, 05:49 pm »
Quote from: Rashiki
Pugs,
 -Rob
Thanks Rob,
I won't be able to test it for a couple weeks.  I just sent my SB3 back to Vinnie to get the updated mods.
Charles Calkins
« Reply #12 on: 7 May 2006, 08:35 pm »
Rashiki spent some time at my house Sat. While he was here he got KKSF dialed into the squeezebox. KKSF music sounds a whole lot better going through the squeezebox rather than the FM tuner.
                          Cheers
                         Charlie
