0 Members and 8 Guests are viewing this topic. Read 16368430 times.
Quote from: martyo on 17 Jan 2008, 11:11 pmSo.. martyo! This image came up on the side of the home page and I traced it to your post in Jan 08.I have a particular interest in that disc as I recorded, mixed and mastered it. Did you like it? (no pressure!)
Do try listening at a volume level that would give you front mid hall seating. I do this alot for onsite recordings. Russell may disagree, dunno, you may too for that matter, but only after you've tried it with this.
Quote from: jimdgoulding on 23 Nov 2009, 11:22 pmDo try listening at a volume level that would give you front mid hall seating. I do this alot for onsite recordings. Russell may disagree, dunno, you may too for that matter, but only after you've tried it with this.That's the level I mix it at, Jim. I try to mix everything at the level it would be, live, in an ideal seating position. So to hear it the way I intended it, it should be played close to that level. If it is played quieter, it will sound a little bass shy and very slightly treble shy.The ol' Fletcher-Munson effect kicking in.
Scott 4 180 gram vinyl Scott Walker
Some serious swingin' blues is a happenin' here, check out the SAMPLES. {the vocals simply kill on Honeysuckle Rose} Cheers,Robin
Quote from: satfrat on 24 Nov 2009, 01:20 amSome serious swingin' blues is a happenin' here, check out the SAMPLES. {the vocals simply kill on Honeysuckle Rose} Cheers,Robin Great stuff, Robin. I love rock-a-billy well done and this is!
A member of the Manhattan Transfer since 1979, Cheryl Bentyne's beautiful voice, wide range, versatility, and impressive stage presence made her into a major asset for the popular vocal group from the start.Cheryl Bentyne - "The Book Of Love".....Cd.....Samples...
