Understand ohms??
0 Members and 1 Guest are viewing this topic. Read 1728 times.
rbrb
Understand ohms??
« on: 23 Feb 2006, 05:12 pm »
I have 4 passive subs with two drivers in each unit.  Each unit is nominally 4 ohms.
If I hooked up two in parallel what would the impedance be?
If I hooked up two in series what would the impedance be?
Impedance is the correct term is it not?
Occam
Re: Understand ohms??
« Reply #1 on: 23 Feb 2006, 05:26 pm »
Assuming you're referring to each of the drivers in each sub being that four ohms and you're talking about series/parallel of the drivers
OR
each of the subs individually, as configured,  rated at 4ohms
NOMINALLY -
In parallel 2ohms
In series 8ohms
Your terminology is correct.
kfr01
Understand ohms??
« Reply #2 on: 23 Feb 2006, 05:30 pm »
I find http://www.bcae1.com/ to be an excellent resource for learning about basic principles relevant to our hobby.
I generally want to vomit when I think of the current state of car audio, but the site contains a lot of great information.
rbrb
« Reply #3 on: 23 Feb 2006, 05:46 pm »
Quote from: Occam
OR
NOMINALLY -
In parallel 2ohms
In series 8ohms
Each individual sub is nominally 4 ohms.  If I understand you correctly then each sub would be...
Nominally- In parallel 2 ohms
              - In series 8 ohms
Thanks for the help and quick reply  :D
rbrb
Understand ohms??
« Reply #4 on: 23 Feb 2006, 05:47 pm »
Quote from: kfr01
Thanks for the link I'll check it out.
Folsom
Understand ohms??
« Reply #5 on: 23 Feb 2006, 06:21 pm »
ohms is a measure of opposition to current  :mrgreen: .
