T amp bridged to mono?
0 Members and 1 Guest are viewing this topic. Read 1684 times.
Christof
« on: 7 Feb 2006, 06:14 am »
Is it possible to make monoblocks from the Sonic Impact Super T amps?
thx...c.
Folsom
« Reply #1 on: 7 Feb 2006, 06:31 am »
If I am not mistaken they are not suppose to be bridged.... There for I doubt there would be a point.
Christof
« Reply #2 on: 7 Feb 2006, 02:08 pm »
Can a T-amp be run with no load on one of it's channels?  I'm building a temporary HT system with Abby clones and would like to power the whole thing with Son of T amps but what do I do when it comes to my center channel?
Thx
c.
Vinnie R.
    • http://www.vinnierossi.com
« Reply #3 on: 7 Feb 2006, 03:35 pm »
Quote from: Christof
Thx
c.
Hi C.
You cannot bridge the Sonic T-Amps...they are already running in a bridge mode for each of the two channels.
Yes, you can one channel with no load....it will not hurt anything.
larry99
« Reply #4 on: 7 Feb 2006, 05:22 pm »
Or convert your center speaker to a bi-ampable configuration. Use one channel for the bass and the other for the mid/tweeters.
Christof
« Reply #5 on: 8 Feb 2006, 04:30 am »
Thanks for clarification.
cg.
