PS Capacitance for tube power amp
0 Members and 1 Guest are viewing this topic. Read 1451 times.
Russtafarian
  • Typical reaction to the music I play
« on: 5 Feb 2006, 09:21 pm »
It's time for me to replace the power supply capacitors in my quicksilver monoblocks.  The amps use Mallory CGS 320uF 450v electrolytics.  Looking at the Mallory CGS page on Mouser.com, I see that I can get up to 800uF 450v caps that will clamp and screw right in.
So is bigger better in this application or should I stay with the same value?
Are there other makes and sources of caps that I should consider other than the Mallorys?
Thanks all.  Happy Superbowl Sunday.
JoshK
« Reply #1 on: 5 Feb 2006, 09:41 pm »
I'd probably stick to the same value unless you have a schematic for the amp.  Here is another source for B+ voltage caps...  http://www.hndme.com/storecapelectrolnich.html
Check out the Nichicon LQ's at 330uf/450vdc for $9/ea.  I have no idea what is better between Mallory and Nichicon but hndme is a tube-o-phile and usually carries what he has liked himself.
Russtafarian
« Reply #2 on: 6 Feb 2006, 04:47 am »
I'll check it out.  Thanks.
Scott F.
« Reply #3 on: 6 Feb 2006, 01:23 pm »
The Nichicons are a nice sounding cap. Personally, I'd steer clear of the Mallory's. I've found them a bit soft and slow sounding.
You may want to consider the JJ's. They are a nice sounding cap too. You have a few other choices but they start to get expensive (but are generally worth the cost). Jensens, F&T's, Black Gates (in limited values), Elna Cerifines (very good but limited values) and the polypropyline Unlytic's look interesting but I've not played with them.
Heres a few links
http://www.thetubestore.com/cancapacitors.html
http://www.partsconnexion.com/catalog/CapacitorsElectrolytic.html
