Bass Amps
0 Members and 1 Guest are viewing this topic. Read 3420 times.
JDUBS
Bass Amps
« on: 1 Feb 2006, 04:29 am »
Hey Guys
I'm currently in the market for a subwoofer amp.  Something "fast"!
In my situation (JBL 4648s @ 8ohms and 100db / 1 watt), I don't think tons of power is really "needed"....but would be nice for a cushion :D
I've heard good things about the Crown K1 (damping factor of 4000?!...sounds good to me!).
I'd like to keep it to $500-$750ish if possible.
Any suggestions??  Hypex modules??
Thanks all!!
-Jim
Levi
Bass Amps
« Reply #1 on: 1 Feb 2006, 04:41 am »
Here you go.  Right in your price range.  Enjoy!
Frequency Response: 20Hz to 180Hz in low-pass mode
10Hz to 28kHz full range
Power Handling: 240 watts stereo, 600 watts mono
Input Sensitivity: 130mV
Phase: Dual mono, continuously variable
Low Pass :  40 to 180Hz, continuously variable
Gain: Dual mono, continuously variable
Power On/Off:  Always on, singal sensing on, remote trigger
Dimensions:  17"W (19" with removable rack ears) x 4" H x 14" D
Weight: 42.5 lbs
Connections: RCA inputs, 5-way binding posts
Available Finishes: Black or silver with black highlights
Warranty:  1 year parts and labor (expanded to 2 years if product is registered within 60 days of purchase)
Front
Rear
gongos
Bass Amps
« Reply #2 on: 1 Feb 2006, 05:35 am »
I have a Dayton 1000 watt plate amp for $300. Tons of power and an EQ. Plus you'd have a few hundred extra dollars to blow.
Red Dragon Audio
    • http://www.reddragonaudio.com
Bass Amps
« Reply #3 on: 1 Feb 2006, 06:36 am »
Adire Audio makes very nice Subwoofer Plate amps as well. :D
JDUBS
Bass Amps
« Reply #4 on: 1 Feb 2006, 11:01 am »
That Anthony Gallo is an interesting amp.  My only question would be how loud is it, given the inclusion of a fan?
I'm considering plate amps as well....just wasn't sure if I was giving up too much in terms of sound quality relative to a "regular" amp.
-Jim
Levi
Bass Amps
« Reply #5 on: 1 Feb 2006, 03:04 pm »
Quote from: JDUBS
-Jim
The noise coming from the fan is negligible and should not be an issue.
If you can find a local dealer you can audition the amp before buying one.
http://www.roundsound.com/default.htm?cid=G-Anthony_Gallo
rbrb
Bass Amps
« Reply #6 on: 1 Feb 2006, 05:54 pm »
The Gallo amp looks like the ideal solution for me except for one thing the price.  Does anyone know of a similar solution for less money.  I'd really like a amp with a built in crossover.
JoshK
Bass Amps
« Reply #7 on: 1 Feb 2006, 06:00 pm »
I'd just get a crown K1 off of ebay for ~$600.
Marbles
Bass Amps
« Reply #8 on: 1 Feb 2006, 06:08 pm »
Or buy Hoosier21's K2.  He has it for $750 OBO.
rbrb
Bass Amps
« Reply #9 on: 1 Feb 2006, 07:24 pm »
The Crown's don't have a built in EQ like the Gallo's which would really simplfy things.
Levi
Bass Amps
« Reply #10 on: 1 Feb 2006, 08:52 pm »
There is one currently at Audiogon for $749
http://cls.audiogon.com/cgi-bin/cls.pl?ampstran&1143468539
And another one for $600
Just right in your budget. :)
Jampot
Bass Amps
« Reply #11 on: 1 Feb 2006, 09:08 pm »
I quite fancied the Gallo and looked for a UK supplier - as usual what costs $999 Stateside is £999 here. :cry:
Ah well...
Jim
Red Dragon Audio
Bass Amps
« Reply #12 on: 1 Feb 2006, 09:16 pm »
Just checking to see if you looked at the Adire Audio subwoofer plate amps.
  • 12dB or 24dB Crossover Slopes (continuously variable from 35Hz - 110Hz).
  • Dual Parametric EQ's
  • 600watts into 8ohms (they have lower powered versions as well)
  • 0° to 180° continuously adjustable[/list:u]
Corbin Johnson
Bass Amps
« Reply #13 on: 1 Feb 2006, 09:26 pm »
http://www.partsexpress.com/pe/showdetl.cfm?DID=7&PartNumber=300-808
I have this $325 Dayton plate amp that VMPS sells as an installed option with their subs.  It also privides the added benefit of a built in crossover/equalizer and dual inputs so you can input directly from a preamp and use the built in equalizer or input from a processor and use the bass equalization from the processor.  I can't find any spec's on damping, but I find it provides quick, tight, clean bass as good as or better than when I was using a 300 wpc Cinenova amp.
Corbin
JDUBS
Bass Amps
« Reply #14 on: 2 Feb 2006, 03:27 am »
Thanks everyone for the suggestions!
Looks like there's quite a bit of support for the Crown amps.
Does anyone know how they fair up to the 200hz. range?  This is the approximate crossover point for my system
Also, does anyone know the slope of the Gallo amp.'s crossover?  Seems like a good choice as well given its feature set.  I'd be curious to know its damping factor as well.
Ryan, thanks for the pics of the Adire!  That is a nice looking amp and certainly worthy of consideration.
-Jim
Levi
Bass Amps
« Reply #15 on: 2 Feb 2006, 04:05 am »
Hi Jim,
You can check the SA's manual.  There is a crossover slope "EQ Boost" measurement.  I hope this helps.
In addition, Galo Acoustics has excellent support which can be found in their website.  It should be the same for Adire or Crown amps.
Whichever amp you choose, make sure you audition it first before buying one.  Paper specs may sound different in real world application. :wink:
Quote from: JDUBS
-Jim
Bob Reynolds
NHT A1 Monoblock amp and X1 Crossover
« Reply #16 on: 4 Feb 2006, 05:55 am »
Used in the NHT Evolution series of speakers and subwoofers. Worth considering I think.
-- Bob
JDUBS
Bass Amps
« Reply #17 on: 18 Mar 2006, 08:04 pm »
All
As an update, I went the Crown K2 route.  Found one on eBay in which the seller was local (unit was close to mint).
Anyway, I got it setup with a Marchand XM-44.
This is one awesome combo!  The Crown has awesome headroom and ridiculous damping of >7000 from 200hz on down.
I've got the Marchand setup for 12db of slope at 160hz.
Thanks for the advice everyone!!  It certainly did help as I've got a terrifically music combo now!
-Jim
