Power Requirements for Multiple Bryston Amps
0 Members and 1 Guest are viewing this topic. Read 2098 times.
danconio
« on: 20 Jan 2006, 07:23 am »
I have 3 Bryston 7B ST amps and 2 7B NRB amps. My question is can I power all of these on one 20A ckt or should I put 2 on one 20A ckt and 3 on the other?
Also if I am rack mounting the amps is 2 rack spaces enough between the amps in a rack?
Jason Nugent
« Reply #1 on: 20 Jan 2006, 02:46 pm »
A 7B amp has the potential to draw 1980 watts when pushing 900w into a 4 ohm load. I'm not an engineer, but it sounds like you'd want to put each amp on its own circuit (1980 VA / 120V = 16.5 A).  A friend of mine has a pair of 7B ST monoblocks and has each amp on its own 20A circuit.   I have a 4B and a 9B and each amp is going on its own 15A circuit.
Definitely, I think you'll have problems if you try to put all the amps on a single 20A circuit.
danconio
« Reply #2 on: 20 Jan 2006, 03:23 pm »
Thanks Jason I see that I need to run a few more circuits into the theater than I was planning.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #3 on: 21 Jan 2006, 12:49 pm »
Hi All,
Remember that the maximum amperage draw is at FULL power into very low impedances. I generally find one 15 amp circuit per Pair of 7B's or one 14B works very well under real-world conditions.
james
eddiem67
« Reply #4 on: 22 Jan 2006, 06:52 am »
you can always pick up a Torus
« Reply #5 on: 22 Jan 2006, 12:42 pm »
Quote from: eddiem67
That's true.
I just installed a 240 volt/60Hz line in my theater room this week and I am using the 60 amp version of the Torus as we speak.
james
danconio
« Reply #6 on: 22 Jan 2006, 05:53 pm »
I would be very interested in your impressions of the difference the Tours made in the sound
« Reply #7 on: 23 Jan 2006, 02:37 am »
Quote from: danconio
OK give me a few days to live with it and I will report back.
james
