Good Wireless 802.11g Router for SB3?
0 Members and 1 Guest are viewing this topic. Read 1771 times.
Horizons
« on: 16 Jan 2006, 05:18 pm »
I currently have a Linksys b-based router. However, I really want to upgrade to a g-based router before installing the SB3 and Slimserver.
Are the Linksys/Netgear/? etc. routers all equally compatible with the SB3 and Slimserver?
Paul_Bui
  • Rode NTK and S-1 microphones
« Reply #1 on: 16 Jan 2006, 05:47 pm »
I've been using a Linksys WRT54G for over a year with success.  However, after playing with the SB2 for several months I think I will upgrade to the Linksys WRT54GS (with SpeedBooster) for even a better wireless performance.  In the interim I added a Linksys Access Point WPA54G and several antennas to boost the signal strength.
mcgsxr
« Reply #2 on: 16 Jan 2006, 05:52 pm »
I had the WRT54G, and it was pretty buggy - lots out there on the Net about how the recent firmware is trash...
I returned it, and have had success with the WRT54GS.
Tweaker
« Reply #3 on: 16 Jan 2006, 07:56 pm »
I have a Linksys WAP54G and it works just fine.
ricmon
« Reply #4 on: 16 Jan 2006, 09:50 pm »
Look for buzz words like MIMO and GbE.  Or just try the D-Link DLG-4300 GamerLounge Router, which specializes in allowing for 256 levels of QoS prioritization. The integrated GamerFuel technology can automatically assign prioritizations, but users can go in and fine-tune a variety of application types, not just games.
edsel6502
« Reply #5 on: 24 Jan 2006, 06:34 am »
The Linksys WRT54G can be found as a bargain.
For the most part. Linksys keeps its firmware fairly up to date.
You can also get opensource firmware if you want fancier features.
DSK
« Reply #6 on: 24 Jan 2006, 07:04 am »
I've been using the Netgear WPN824 MIMO router (7 internal antennae) that automatically configures itself for the best signal path. It is upstairs and a room across from the SB2 and gets 85% signal strength. Never had a dropout. I believe Wayne at Bolder Cables uses the same router.
The netgear website has a link to independent measurements that were done, comparing the signal strength (straight line and through walls) against the Linksys WRT54 and something else (can't remember).
