0 Members and 1 Guest are viewing this topic. Read 3284 times.
I started ripping a few CDs with iTunes to Apple lossless. Sounds great but the average CD is ripping to around 250-300 MB (roughly half of the total wave file size). I originally thought that I could rip 1000 CDs in this format and that it would fit on a 250 GB drive. I see that I can only fit about 100 CDs in Apple lossless on 250 Gigs. Is my math right? If so, I either need a much bigger drive(s) or a switch to FLAC to get more compression. I guess adding multiple drives is another option.
Your math isn't quite right. If you're getting 300MB per CD, that'll let you rip about 3 CDs per 1GB. So on a 250GB drive, you should be able to get about 750 CDs (a lot more than 100 CDs)...
Quote from: PhilNYCYour math isn't quite right. If you're getting 300MB per CD, that'll let you rip about 3 CDs per 1GB. So on a 250GB drive, you should be able to get about 750 CDs (a lot more than 100 CDs)...Thanks for the clarification. I plan on using both EAC/FLAC and iTunes/Apple Lossless and do some sonic comparisons.
You will find FLAC better I am sure. I noticed a huge difference in transparency and dynamic range.
I have a related question...I just got a 250gb external HDD. I was trying to use the backup software to back up the pictures as well as the Itunes folders which include everything I have in terms of Apple Lossless and MP3s. What I realized after spending a good 30 minutes to 1 hour letting the backup take place was that the backup was incomplete. I mean, the Iphoto files end up to about July 2004 and it stopped there. The same happened to Itunes files, it goes from whatever lose MP3 to a point and it does not want to copy Itunes music folders and its subfolders. I was able to drag and drop copy the missing files but the software tells me that "the name path is too long" whatever nonsense and I have to skip that file to continue the backup path. What is happening here.
Quote from: Destroyer of Smiles.You will find FLAC better I am sure. I noticed a huge difference in transparency and dynamic range.Depends on what you're using for playback, no? If using a Squeezebox, Slimserver converts Apple Lossless to FLAC before sending it to the Squeezebox...
Now that is something interesting that I did not know. Is there a utility to convert Apple lossless to FLAC?
Quote from: PhilNYCQuote from: Destroyer of Smiles.You will find FLAC better I am sure. I noticed a huge difference in transparency and dynamic range.Depends on what you're using for playback, no? If using a Squeezebox, Slimserver converts Apple Lossless to FLAC before sending it to the Squeezebox...Now that is something interesting that I did not know. Is there a utility to convert Apple lossless to FLAC?
