0 Members and 1 Guest are viewing this topic. Read 3566 times.
I have a 116" 4:3 screen, so I know what you are talking about. I found that nixing the center is the best solution for me. In the AVR config screens, I set the center channel to NONE, so the AVR sends the center channel content to the Left and Right channels. I have the center speaker in place, but it is just not active, and people don't believe me when I tell them it is not active as the voices really do sound like they are coming from the center speaker.
Is this how one achieve the so called "phantom centre"? Got to try it too...
I would recommend trying no center. You might be surprised at how good it is.
It's just me but I have found no example of when a phantom center is better than my center in any way. Hirez multichannel, 7.1 DVD movie soundtracks, DTS 5.1 cd listening, etc. YMMV.
Quote from: ted_bIt's just me but I have found no example of when a phantom center is better than my center in any way. Hirez multichannel, 7.1 DVD movie soundtracks, DTS 5.1 cd listening, etc. YMMV.No one is saying that a phantom center is better than a dedicated center channel under ideal conditions. Keep in mind that you have an ultimate set up with few, if any, comprimises. Most of us have to live with signifcant comprimises, and constant WAF issues.
The easiest thing to do would be to get your speakers before you get the screen and center channel. Then play your DVDs in phantom mode and see if you are happy. If so, problem solved. Buy the best screen you can justify and you'll be extremely happy. If you're not satisfied, then think about whether you want the center channel behind or below the screen and buy the screen accordingly. The only thing you wouldd have lost is a little time. If, on the other hand, you decide you don't need the center channel, ...
Pennylane, Do you not have your speakers? Are you using the Polks as mains?
