Where to buy Blue Tak or other equivalent?
0 Members and 1 Guest are viewing this topic. Read 1097 times.
pennylane
« on: 29 Dec 2005, 02:32 am »
Where can I get it?  Or should I try some other substance?  I remember reading somewhere that Blue Tak would stick to the speaker and the outer part of the wood would peel off.  Are there other substances you recommend?
Thanks in advance
eric the red
« Reply #1 on: 29 Dec 2005, 02:36 am »
Office Depot-Elmers Fun Tack about a buck a package :mrgreen:
djbnh
« Reply #2 on: 31 Dec 2005, 02:08 pm »
Michaels, Home Depot, Lowes, etc
pennylane
« Reply #3 on: 12 Jan 2006, 08:11 pm »
What exactly should I get?
Reusable adhesive?  Not tacky glue, right?  It comes in like a stick or something and you can peel it off and stuff like that?
Something like the "DAP Fun Tak" listed at: http://www.office1000.com/discount/adhesive-reusable.html
(near the bottom)
Thanks.
PhilNYC
« Reply #4 on: 12 Jan 2006, 09:06 pm »
Here's a place you can get "the original Bostik Blu-Tak"
http://www.neverseezproducts.com/BluTack.htm
$27 for a pack of 12.  Note that each pack contains something like six 8"  strips, and each strip is probably good for 4 pairs of speakers.  So for $27, you have enough Blu-Tak for about 280 pairs of speakers.... :D
Kenobi
« Reply #5 on: 13 Jan 2006, 12:01 am »
Phil,
Thanks.  This is BY FAR the best price I've seen for blue-tak so far.
Kenobi
