0 Members and 1 Guest are viewing this topic. Read 1816 times.
If you use the digital out on the SB3 to an external DAC, does this disable the SB3 remote volume control?
You have to disable it in Slimserver Player Settings/Audio. There is a dropdown for Digital Volume Control, set it to Digital Output Level Is Fixed.
Quote from: HorizonsIf you use the digital out on the SB3 to an external DAC, does this disable the SB3 remote volume control?Hi Horizons,In the Slim Server software, you have the option of setting the digital output to "fixed," or adjustable via the remote.Regards,
