0 Members and 1 Guest are viewing this topic. Read 4424 times.
Does it have an ethernet port on the back of it? If so, then yeah, you can run it wired.
I don't have a SB but I've found that unplugging/replugging the router and restarting my PC helps when I can't get on to my wireless network.
Guess I'll give them a call today...otherwise, out it goes. Thanks !!
Quote from: bubba966Does it have an ethernet port on the back of it? If so, then yeah, you can run it wired.Yes it does...so I'll give that a try then. I could not get it running as a wireless...even using two computers....
Chris, Walls in HK are very thick so I can only get my laptop as far as halfway into the next room before I lose signal from my D-Link 802.11g router. I will try one of the new NIMO wireless routers but sometimes wonder if I shouldn't just run cables to my laptop and my wife's and ...
I would assign a static ip address to your squeezebox. You will need to find out your computers ip configuration. The easiest way is to open the command prompt and type "ipconfig /all" (no quotes). This will give you the info you need. Write down your computers ip address, the subnet mask (usually 255.255.255.000), your default gateway, and dns server numbers. Now go to the "setup networking" and start the "setup a wireless network" as usual. After it detects your access point you will have the option to en ...
