0 Members and 1 Guest are viewing this topic. Read 12029 times.
I'm running $9k speakers with a $1k amp and lovin' it! To do cheap amps, I think you need efficient speakers.
I did an experiement a while back in which took my expensive electronics and mated it with my under $1k JM Reynaud Twins MK II speakers.
I really need to get up to your place in the Spring for a kickin listening session.
...or powered subs
George,I may have to make that trip with you. I am most intrigued with some of Bill's offerings. Hi-efficiency and triodes is something I need to experience still.
The D2s have great bass but I have yet to hear a speaker with the tightness in the lower region as the DA-1s.
Another day brings about another experience with the Usher D2's. I had a customer drive up from PA the other day to drop of a pair of Welborne Labs DRD 45 mono blocs (i'll post pictures a bit later). This morning I had to hook them up to the Usher D2's to see what 1.5 watts would do. I have the Usher D2's still running as 8 ohm speakers with the ZERO-Autoformers. I was quite surprised with the results with only 98dB. In comparison to the Almarro EL84 SET (4.5 watts), the DRD 45s have mush more body ...
Bill, if you think Sylvania 45 sounds good and has good bass, you MUST borrow/steal EML 45 solid plates to try. The amp will sound like it has twice the power subjectively.
BTW, do you have the latest version of Almarro A205A with headphone output? I love how this little thing sounds, and I have owned 45SET before. I would love to hear more about Almarro vs. DRD45...
I thought those little s520 there ontop only came in that really reddish birch, is the lighting making them look like that on the pic or is it a different finish?
