Are the bi-fet parts reused in An OmegaStar PAT-5?
0 Members and 1 Guest are viewing this topic. Read 2963 times.
daveshel
« on: 27 Nov 2005, 05:52 pm »
I have an older PAT-5 and a newer PAT-5 bi-fet and want to do an OmegaStar rebuild. If I am reading the Web site correctly, all the audio boards are replaced as part of the rebuild, so I might as well start with the older unit. Correct?
avahifi
    • http://www.avahifi.com
« Reply #1 on: 28 Nov 2005, 03:55 pm »
All other things being equal, use the Pat-5 in the best physical condition.  Some parts are recycled, including the pushbutton switches, tone controls, selector switch, and jacks (unless you add the jack set kit option).  If both Pat-5s are working now, check them out for good signal continuity on all the jacks and switch functions.  A major switching dropout in the main bank of pushbutton switches is a real pain in the ass to deal with after the fact.
It does not matter which version of the Pat-5 you use from a circuit standpoint, the audio circuits are replaced, the important things are the condition of the necessary recycled hardware.
Frank Van Alstine
daveshel
« Reply #2 on: 1 Dec 2005, 03:16 am »
Quote from: avahifi
It does not matter which version of the Pat-5 you us ...
Thanks.
Is the fiberglass selector switch the same as the one for the PAS3? That's the only one I see on the price sheet.
avahifi
« Reply #3 on: 1 Dec 2005, 01:50 pm »
Yes, it is the same switch.  It can be configured for all of the different applications we need for all our preamplifiers.
Frank Van Alstine
daveshel
Project completed
« Reply #4 on: 29 Dec 2005, 01:52 am »
I am listening to my OmegaStar PAT-5 and I am amazed. Cool, crisp and clean. I got the kit version along with the jack set and selector switch. Worked on it a couple hours each day for about 8 days, taking it slow and careful. Right away I noticed a vastly improved clarity and detail and mids and highs that are sweet and smooth and more present than ever before but not harsh like some solid state equipment. I didn't think these speakers could sound this good.
Kudos, Mr. Van Alstine.
guest1632
  • Guest
Re: Project completed
« Reply #5 on: 31 Dec 2005, 07:23 pm »
Quote from: daveshel
Hey Dave, what speakers you using? Since we are both in Tucson, will have to get together with you sometime. I need some egemacation as to this new fangled tube stuff. My last exposure to tube stuff was some modified Mike Mofett Stereo 70's.
Ray
daveshel
« Reply #6 on: 2 Jan 2006, 01:50 am »
Stacked Advents.
skrivis
« Reply #7 on: 2 Jan 2006, 01:39 pm »
Quote from: Ray Bronk
Ray
Dave's OmegaStar PAT-5 is actually solid-state, but...
I find that AVA gear doesn't really have a "tube" or "solid state" sound. It just sounds good. :)
guest1632
  • Guest
« Reply #8 on: 2 Jan 2006, 04:32 pm »
Quote from: skrivis
Ray
Well, I suppose that's how electronics should sound, with no sound to call its own.
