Opinions on Power Chip Amp
0 Members and 1 Guest are viewing this topic. Read 2987 times.
Folsom
« on: 15 Nov 2005, 02:45 am »
http://www.madaboutsound.com/prod_det.asp?product_id=1
I was thinking of ordering this and all the extra componets from that particular website. I decided my Rotel might be a little to much effort for nothing much. Not saying I will order this right now, but possibly. I need to find a stylus :evil:
peranders
« Reply #1 on: 18 Nov 2005, 10:56 am »
Why not. You can buy those things also from
www.chipamp.com (he has made the pcb's)
www.audiosector.com (he is the designer)
and you can also buy from me but a bit more advanced Gainclone...
Gordy
« Reply #2 on: 18 Nov 2005, 01:32 pm »
DoS,
If you're not already familiar with these sites, there's enough info to keep you busy awhile...  http://www.diyaudio.com/forums/forumdisplay.php?forumid=40
http://myweb.tiscali.co.uk/nuukspot/decdun/gainclone.html
Folsom
« Reply #3 on: 18 Nov 2005, 08:40 pm »
I actaully found http://www.diyaudio.com and posted, discovering that I need a pre-amplifier for my turn table, so...... I could use it for my computer intput, but the turntable needs like a 50db boost or some thing like that.
I have to check but perhaps I could use my Rotel's output into the amplifier, just use it as a pre-amplifier.
peranders
« Reply #4 on: 19 Nov 2005, 07:46 am »
So, what are you missing and what do you have?
You seems to be missing at least a RIAA amp for your turntable. I have two massive designs and Mr. Hagerman has his Bugle and you have a lot more altenatives.
http://www.hagtech.com
http://home.swipnet.se/~w-50719/hifi/qsxm3
http://home.swipnet.se/~w-50719/hifi/qsxm2
Folsom
« Reply #5 on: 20 Nov 2005, 06:01 am »
I have a reciever that does both, a Rotel RX-203.
I was looking at the power chip amp caues it is very inexpensive and powerful. I also looked at this
https://secure.tubesandmore.com/
the one for $139.
Peranders those are your designs? That is sweet, I however predict the costs are more then the Bugle if I just buy the plans and PCB, parts are under $40.
I had considered a tube pre-amplifier, but a tube amplifier might just be the ticket considering price differences. The lower no DIY kit tube pre-amplifier, the DOD entry level, is a fantastic price for fantastic entry level pre-amplifier, however it will cost more then a small tube amp and pre-amplififer Bugle combined. I have no fear of building any thing, I can solder, and know people that can solder circles around me if I need assitance with some thing only an expert can solder.
Thanks again for the information.
peranders
« Reply #6 on: 20 Nov 2005, 07:46 am »
Sorry, but I still can't see what you are asking.
Folsom
« Reply #7 on: 20 Nov 2005, 11:38 pm »
Quote from: peranders
Just opinions on what to do.
lbo
« Reply #8 on: 22 Nov 2005, 01:38 am »
Quote from: Destroyer of Smiles.
sounds like you are after the chip amps for simplicity. if that's the case, you may also want to drop an opamp-based riaa amp in the chip amp of your choice then you are ready to go - alternatively, you can drop that riaa equilization circuitry into your turn-table and output a line level signal to the standard chip amp.
either way, it is going to be very easy if you are comfortable with soldering - you must be otherwise you shouldn't be looking at the kits.
