Recommendations for Computer Speakers
0 Members and 1 Guest are viewing this topic. Read 2277 times.
Doublej
« on: 1 Nov 2005, 01:55 pm »
I am looking for a small pair of self powered speakers to mate with my computer. Does anyone have a recommendation?
Specifically has anyone heard the FPSs and care to comment on them?
dogberry
« Reply #1 on: 1 Nov 2005, 01:58 pm »
What's your budget?
For $179 I don't think you can beat the Swans M-200.
Doublej
« Reply #2 on: 1 Nov 2005, 04:29 pm »
Ideally $125. And I wanted to keep them fairly small.
Where can one get the M-200s and what do you think about the Swans S200A?
http://www.swanspeaker.com/product/htm/view.asp?id=256
yo2tup
« Reply #3 on: 2 Nov 2005, 12:23 am »
I have some swans m200 that i'll sell you for $125.  Let me know, thanks.
Carlman
« Reply #4 on: 2 Nov 2005, 12:55 am »
Please PM people if you want to try to sell something.
warnerwh
« Reply #5 on: 2 Nov 2005, 01:00 am »
The best set of computer speakers I've heard are Monsoon MM 1000's. Just sold mine due to the fact I use headphones now but they sound great. You even get good imaging with your monitor in the middle. You can only get them used on Ebay but they still go for about 150-175 a set.  They're worth it though, I could listen to music and not feel like the sound was holding back the enjoyment like most computer speakers I've heard.
ehider
« Reply #6 on: 8 Nov 2005, 09:44 pm »
I am a HUGE fan of the Midiland S2 with the included sub and controller.
http://www.tweak3d.net/reviews/s2midiland/4100/
A couple years ago I did a comparative against everything I could find under the $500 price point (Monsoon, Aletc, Klipch and the like) and this system was far far better in terms of real bass balance, excellent refined highs and midrange voicing by a long shot .:!: .
I'm not sure if it is still available anymore on the new market, but if you can still find this system I'd recommend over anything else that's available under the $700 price point circa 2006 (it's that damn good IMHO!). :mrgreen:
eric the red
randytsuch
« Reply #8 on: 9 Nov 2005, 03:06 am »
I bought a pair of monsoons from a guy at diyaudio.  I have them hooked up to a rio karma and listen to it at work.
Sounds pretty good for what they are, but I have not heard the Swans to compare them.  They beat the hell out of the altec's I used to use.
I do have two subs instead of one, and that does make them sound better.
Randy
Doublej
« Reply #9 on: 9 Nov 2005, 05:59 pm »
I have heard from multiple sources that the Monsoons are very good. But they are also very difficult to find!
