HTPC to SP1.7
0 Members and 1 Guest are viewing this topic. Read 2076 times.
gazza982
HTPC to SP1.7
« on: 27 Oct 2005, 01:02 pm »
Hi,
While I normally use a scaler for my Plasma and Projector I've recently built a HTPC.
The results are quite good except the SP1.7 won't pick up the S/PDIF digital out signal from the sound card.  I'm using a digital coax cable obviously with a mono 3.5mm plug adaptor.
I have locked the Aux coax connector to digital and set the opt1 and opt2 to none.  The S/PDIF setting on the soundcard is also set to output digital only.
It works with an old Denon receiver so I can't work out what I've missed with the SP1.7.
I haven’t tried the optical connectors as I’ve lost my TOS cables.
Any suggestions?
Gaz
thomaspf
HTPC to SP1.7
« Reply #1 on: 27 Oct 2005, 05:14 pm »
Works fine here.
However, I am not sure what a mono 3.5mm plug adaptor is?
I am using a variety of soundcards which have standard coax outputs and the SP1 is very forgiving (consumer, pro, data, non data) in latching onto an incoming digitial signal.
I have the best interoperability with Windows system sounds, an ASIO media player, and TheaterTek using an old M-audio DIO24/96. The ESI-Pro Juli@ also works fine.
In digital mode I use pass through which will switch automatically to the PCM output rate 44.1/96 or to DD/DTS.
Given the current feature set of the SP1.7 my final setup is a bit more complicated with a dejitter box and a digital equalizer looped into the digital chain.
Cheers
    Thomas
  • The Demo is Everything!
    • http://www.bryston.com
Re: HTPC to SP1.7
« Reply #2 on: 27 Oct 2005, 06:50 pm »
Quote from: gazza982
Hi,
It works with an old Denon receiver so I can't work out what I've miss ...
Hi, please ask him if the green digital light is on, or if it's red.  And what is showing on the display - does it say "analog" or "detecting" or something else.
-sp
gazza982
Re: HTPC to SP1.7
« Reply #3 on: 28 Oct 2005, 05:35 am »
Hi James/Shane
Quote from: James Tanner
-sp
The red light is on and the display is showing detecting.  As Thomas mentioned I have the mode set to 'pass through'
My first thought was that the sound card S/PDIF connector is in analog mode but the Denon is picking up a digital signal.
Sorry I didn't phrase that very clearly.  I'm using Nordost Moonglo II RCA to RCA digital cable with a RCA to 3.5mm Plug adaptor to fit the soundcard.
I will fit a Lynx card at some stage but at present it's just a Creative Sound Blaster X-Fi Elite Pro.
Thanks for helping.
Gaz
gazza982
HTPC to SP1.7
« Reply #4 on: 28 Oct 2005, 05:42 am »
Thomas,
Could you tell me what dejitter box you are using as I'd like to test this out on my system?
Regards
Gaz
gazza982
HTPC to SP1.7
« Reply #5 on: 31 Oct 2005, 05:28 am »
Works OK with the Motherboard built in s/pdif connection so it looks like an issue with the sound card.
Thanks to everyone that helped.
Gaz
thomaspf
HTPC to SP1.7
« Reply #6 on: 3 Nov 2005, 07:17 pm »
I am using a pretty dated Monarchy Audio DIP 24/96 . I also have a 2 channel digital equalizer looped-in between my PC and the DIP.
I guess the equalizer will be gone soon but  I am still patiently waiting for an effective dejitter mechanism ....
Cheers
    Thomas
gazza982
HTPC to SP1.7
« Reply #7 on: 8 Nov 2005, 06:14 am »
Thanks Thomas :thumb:
