SB3 released
0 Members and 1 Guest are viewing this topic. Read 2143 times.
BradJudy
SB3 released
« on: 25 Oct 2005, 02:12 am »
The new SB3 has been released.  Just when you thought you were caught up with new products Wayne.  :)
http://www.slimdevices.com/
$249
$100 off of 2 coupon listed on the front page.
Wayne1
SB3 released
« Reply #1 on: 25 Oct 2005, 02:21 am »
How many places should this be announced :lol:
http://www.audiocircle.com/index.php?topic=22477
http://www.audiocircle.com/index.php?topic=22480
http://www.audiocircle.com/index.php?topic=22476
It is the basically the same as the SB2 in a new, fancy case.
The 3.3 volt regulator has been changed to a linear supply rather than the switcher (which I do as part of the mod to the SB2) and the antennas are both internal.
It does look like it may be a bit hard to fit the big Sonicap coupling caps inside the case.
I suggest you pick up the SB2 while there are still some left.
If you want the new SB you can enter code ThankYou at the check out to get an additional $20.00 off
Music Machine
SB3 released
« Reply #2 on: 25 Oct 2005, 04:57 am »
Maybe a hole could be cut into the back of the SB3 to make space for larger caps?  :roll:
Regards
CornellAlum
SB3 released
« Reply #3 on: 25 Oct 2005, 10:35 am »
I wonder if the price won't drop quite a bit more on the sb2 as they transition to the new one...hmm
