New Squeezebox
0 Members and 1 Guest are viewing this topic. Read 2257 times.
Wayne1
New Squeezebox
« on: 25 Oct 2005, 12:24 am »
Slim Devices just announced their third generation SB.
New software to run it, too. Slimserver 6.2.
It is a slimmer case with two internal antennas.
It looks like it might be a bit hard to fit the big coupling caps in this case  :cry:
The old SB 2 is still available and is still on sale. The new SB is on a promo where you can get $100.00 off if you buy two.
http://www.slimdevices.com/index.html
ctviggen
New Squeezebox
« Reply #1 on: 25 Oct 2005, 01:05 pm »
An interesting dilemma. Do you buy two old ones (wired) for $360 or two new ones for $400?  Or do you wait for the sale at Christmas?
By the way, Wayne, how do you figure out the size of the coupling caps?  I ask because I'm fixing/modifying my Creek integrated amp and wouldn't mind throwing in larger and/or better caps if I could determine what size and type to throw in.  I'm currently just going to replace the caps with nicer quality caps of the same size.
