0 Members and 1 Guest are viewing this topic. Read 13592 times.
The third-generation Squeezebox has a completely redesigned form factor and is functionally identical to Squeezebox2. No need to upgrade for most of us. They are also offering $100 off if you buy 2. Anyone interested in a power buy?Joe M
I might be interested provided they can be modded just as well.
Quote from: maxwalrathI might be interested provided they can be modded just as well.After posting about the quantity discount, I saw a post by Wayne saying the old squeezebox II would be better for modding, it has more room inside for the coupling caps.So, I might end up getting the II instead.Randy
SB3 has 99.9% the same circuitry and measures identically to SB2 on the standard DAC tests (THD, noise floor, etc).The change to use a linear reg for the 3.3 rail improves jitter measurements, but it's already so close to measurable limits for the equipment I have that it's getting hard to quantify.
I will contact Slim Devices about a quantity discount. I will also ask about the availability of SB2's and SB3's. If you are interested in a power buy, hold off buying until I find out what can be done. It would be worth it if we can save some money. Maybe Vinnie and Wayne would be interested in a Power buy for there mods? Also, I'm crazy busy right now. If someone else has a connection with Slim Devices or someone has interest in coordinating this power buy, that would be great. Maybe we could ha ...
I asked about group discounts and they were very small.We would probably be better served by doing it all on AC and just going with the $100 off when you order two units promotion they are currently running.george
