0 Members and 1 Guest are viewing this topic. Read 5419 times.
I've just got my midrange panel back from VMPS for one of my 626Rs... re: hooking it upIs the red/green wire positive? Does this go to the terminal marked positive on the front side of the panel?Thanks in advance,Patrick (J Harris)
I've hooked them up as you suggest though and the sound is even between the two.
If it sounds good, its fine I like the 626 also a lot, i have one herr and actually like it more then the RM30. If you give them 8 feet to the frontwall they can potray a very nice and layered soundstage. A very good speaker in my book. -Flo
Florian,Can you get ahold of some 1" dowel rod, this is often used for hanging cloths in a closet.If so, you can always add bracing to the RM30 to help with the <200 Hz tones...BH5 or whispermat for damping won't hurt either.The dowels seemed to work well for my (previously) totally unbraced RM40's.
I thought the new cabinets for the RM30s and 40s were braced inside. Is that not correct?
Well i took my 30's apart to stop the anyoing rattling inside. And there is pretty much nothing inside. Some white stuff sprayed on the inside which i asume is this soundcoat and there was some fluffy stuff between the seperate chambers for the midragne drivers. -Flo
All mls cabinets have bracing.
I have been inside my 626 mls cabinets recently to add bracing if need be, and ended up taking a trip to the local store for oak dowels. I honestly have to say, what bracing? My blackhole 5 should be here this week for them as well.
