0 Members and 1 Guest are viewing this topic. Read 6468 times.
However, you and dwk both brought up a very good point about CD (into 180º) going to cause more room interaction. I don't know how you can get around that.
Do you want your cake or do you want to eat it?
Wouldn't it be better going forward to design a new speaker that uses 8" H 2/3"w ribbons to begin with? That way there would be little need for a WG (if I understand what you are trying to do).
Before the pictures were shown, I was envisioning something more like a replacement panel driver with an integrated waveguide plate. I wonder if this might be the another possible direction.
Quote from: MarblesHowever, perhaps there is a greater degree of difficulty building and/or mounting a 2/3" ribbon?-KJPanels distort near the edges. Putting edges closer together doesn't eliminate that, if anything, it might be worse. It looks like the goal is to mask off the edges, instead.
In my opinion, the 180 degree pattern is quite beneficial, and is a significant net improvement in terms of room interaction.
