0 Members and 1 Guest are viewing this topic. Read 12068 times.
These Salamander amp stands look like they'll work well with the RM-30's. They're 23" wide, 16" deep, and 3.75" tall. I'll orient them so they'll be 23" deep and 16" wide. If I've measured correctly, the speakers will fit perfectly inside the four protruding Allen nuts on top. I hope they are high enough off the floor: the blocks + boards I'm using now are about 5.5" high and that's a nice improvement over floor placement. I ordered a pair in black from Audio Advisor.
Meanwhile I'm back listening to the previous set up and I find I'm enjoying it even more. It's like coming home again, except I seem to be hearing even more from my old favorites. What's going on? Have I aligned the speakers in some slightly different orientation - I don't think so. The Behringer is definitely using the same readings.Could it be psychological? Have my ears and/or brain reacted to the unfamiliar sound I got from the Talboy experiment? Whatever it is, I'm again loving my music again.
