PMC IB2 versus MB1s
0 Members and 1 Guest are viewing this topic. Read 3977 times.
Jeroen
PMC IB2 versus MB1s
« on: 12 Oct 2005, 09:52 am »
I am looking to upgrade to either new pmc IB2s or nearly new MB1s.
Has anyone compared these speakers, and what were your finding?
Regards
dan_lo
PMC IB2 versus MB1s
« Reply #1 on: 12 Oct 2005, 11:03 am »
I compared the IB2 to the MB2. The difference is considerable.
The IB2 is excellent but the MB2's sound is simply more realistic.
Jeroen
PMC IB2 versus MB1s
« Reply #2 on: 12 Oct 2005, 11:18 am »
Ok but the mb2s are a bit above my budget, so I want to find out how the older mb1s are performing agains the new IB2s.
I have heard the MB1s and thought they were very good.
I however have never heard the IB2s but I was told that they perform better then the MB1s.
I was also told that the new IB2s have the same mid and high drivers as the mb2s, and all though the MB2 are sonically better this is mainly noticable when you compare them side by side.
So I want to find out what the strenghts and weakness are of the IB2 and the MB1s.
guest2521
  • Guest
ib2 v mb1
« Reply #3 on: 19 Oct 2005, 10:05 am »
The only difference between the mb1 and the mb2 is the cabinet and the crossover I beleive. So the ib2 v mb1 should boil down to the newer crossover versus the bigger driver. I am sure you could upgrade the mb1 crossover to mb2 spec so I would go for the mb1 abnd upgrade the crossover. The mb1 cabinet doesnt have the rounded edges of the mb2 cabinet.
Jeroen
Re: ib2 v mb1
« Reply #4 on: 19 Oct 2005, 10:15 am »
Quote from: biovizier
Thank you for the info.
I have scheduled a demo of the IB2, MB1 and MB2 to help make up my mind.
regards
dan_lo
Re: ib2 v mb1
« Reply #5 on: 19 Oct 2005, 10:43 am »
I believe you are wrong. They upgraded the Bass driver .
dan_lo
PMC IB2 versus MB1s
« Reply #6 on: 19 Oct 2005, 05:21 pm »
The difference between MB1 and MB2:
http://www.audiocircle.com/index.php?topic=18003
Thunder
PMC IB2 versus MB1s
« Reply #7 on: 6 Nov 2005, 06:18 am »
Quote from: dan_lo
I disagree, the MB 1 or 2 do not sound any more "realistic" than the IB2's. I've compared all three and found that IB2's have better imaging and the bass response is not as dry - IB2's have more kick. As such, I preferred the IB2's, especially in an average sized rooms. The only reason to ever consider an MB1 or 2 is if you have an unusually large room IMHO.
guest2521
  • Guest
PMC IB2 versus MB1s
« Reply #8 on: 6 Nov 2005, 09:28 am »
What room size did you compare them? The mb2s need a huge room for the bass and imaging to be correct.
Thunder
PMC IB2 versus MB1s
« Reply #9 on: 6 Nov 2005, 04:40 pm »
That's exactly my point, I agree with you. It's important that people realize this when considering which to buy. I tested in two different rooms, one was 16' wide by 21.5' deep and the other was 18' wide by 23' deep. These are mid sized rooms and the I personally preferred the IB2's in both rooms.
guest2521
  • Guest
PMC IB2 versus MB1s
« Reply #10 on: 9 Nov 2005, 01:39 pm »
You need a bigger room and the mb2s way clear of boundaries.
