MB1 vs MB2
0 Members and 1 Guest are viewing this topic. Read 3268 times.
freakygreek
MB1 vs MB2
« on: 30 Mar 2005, 04:07 am »
I would like to know what the differences are between these two models.
        Cheers
  • The Demo is Everything!
    • http://www.bryston.com
MB1 vs MB2
« Reply #1 on: 30 Mar 2005, 12:18 pm »
The MB1 was the first of the MB series and was replaced with the MB2 about 3 years ago.
The MB2 has the crossover and amplifier connections directly on the back panel of the speaker and has a curved front baffel for better imaging stc. The MB2 also has a much thicker front baffle to reduce resonance.
If it is a very early MB1 it may have the older midrange unit instead of the PMC midrange unit that all MB2's have. You can tell if it is the older mid because it will have 2 little wires coming out from under the mid-dome.
james
dan_lo
MB1 vs MB2
« Reply #2 on: 30 Mar 2005, 02:32 pm »
Correct me if I'm wrong, but I remember that the bass unit was also upgraded about a 1-2 years ago.
MB1 vs MB2
« Reply #3 on: 30 Mar 2005, 02:56 pm »
Thanks Dan your right - It was the same 12 inch driver but they extended the 'throw' and went from a cotton surround to a rubber.
james
freakygreek
MB1 vs MB2
« Reply #4 on: 30 Mar 2005, 08:36 pm »
Thanks for the info.
