Best Subwoffers for music under 600$ used
0 Members and 1 Guest are viewing this topic. Read 1480 times.
rgurujal
« on: 9 Oct 2005, 08:41 pm »
Hi,  I,lurk here a lot but rarely post.  I have a musical fidelity integratrd as my main amp driving a pair af b and G corp radia 520 planar speakers.  I was wondeing if anyone has opinions on good cheap subwoofers for music.  I have considered SVS.Hsu, piinnacle digital, PSB,and kef psw 3000, but as these are hard to audition I really don't know how they will blend in with th the planars.  Any oponin is appreciated.  I live near chicago now, having moved for st louis
tex-amp
« Reply #1 on: 10 Oct 2005, 12:10 am »
Watch for an ACI Force to come up.
ScottMayo
Re: Best Subwoffers for music under 600$ used
« Reply #2 on: 10 Oct 2005, 12:47 am »
Look for a used VMPS "Larger." Or if you can go a bit higher, you could get a Larger, new. Highly recommended.  :D
Carlman
« Reply #3 on: 10 Oct 2005, 12:55 am »
Just a reminder.. Please make dealer offers in PM's.... Thanks.
JoshK
« Reply #4 on: 10 Oct 2005, 02:22 am »
Dipole is suppose to blend the best with planars.  Check out linkwitzlabs.com and the pheonix dipole woofers project.  That should give you some ideas, but not an off the shelf product.
Parnelli777
« Reply #5 on: 10 Oct 2005, 12:31 pm »
Your own Bohlender-Graebener makes the Radia Z SUB. It's absolutely excellent, although there's now a newer version that my dealer carries with a passive radiator. The original Z sub is only $900 new.
rgurujal
thanks
« Reply #6 on: 10 Oct 2005, 02:05 pm »
Thanks for the replies folks.  I will check them out.
