What do you think of Rotel RCD-1072 and Arcam 73T?
0 Members and 1 Guest are viewing this topic. Read 3697 times.
michaelv
« on: 26 Sep 2005, 04:57 pm »
Hi,
  I was wondering if anyone compare two CD players Rotel RCD-1072 and Arcam 73T? Which one is better in term of build quality and sound?
thanks very much.
PhilNYC
« Reply #1 on: 26 Sep 2005, 05:56 pm »
My experience with Rotel and Arcam are that they are pretty much on opposite ends of the spectrum sonically.  Which one is "better" is a matter of taste.  FWIW, I used to own an Arcam FMJ-CD23, and I bought my dad a Rotel system a few years ago, so I've spent some time with both...
IMHO, Rotel tends to have a dark and weighty sound, whereas Arcam is more open and lean.  Both IMHO are smooth, although Arcam might win the smoothness battle between them.
michaelv
« Reply #2 on: 27 Sep 2005, 07:42 pm »
Thanks.
Does Arcam 73 play HDCD disk?
thanks.
mcgsxr
« Reply #3 on: 28 Sep 2005, 12:33 am »
according to a quick google search, it would appear that the Arcam does not play hdcd discs.
Well, ok, I should say that it does not decode hdcd portions of discs, for all y'all being specific!
KJ
« Reply #4 on: 28 Sep 2005, 12:46 am »
Quote from: michaelv
I'd check with some Rotel owners regarding build quality if possible.  I have heard some rumblings in the past about quality control issues with other Rotel products.  It may or may not apply to the RCD-1072.  Both units have received favorable reviews.  The Rotel had a review written by The Absolute Sound, and the Arcam had reviews written by Hi Fi News, Hi Fi World and What Hi Fi.  Might be worth digging up.
I haven't personally heard either in person, so I won't shamelessly plug the Arcam.  I'd recommend demoing each if possible.
-KJ
WEEZ
« Reply #5 on: 28 Sep 2005, 12:55 am »
..agree w/ Phil regarding differences in presentation.
The Arcam 'seems' to have a better quality 'feel' to it. (feel of the controls, etc.) And it's upgradeable to the CD192....
FWIW..
WEEZ
guest1632
  • Guest
Re: What do you think of Rotel RCD-1072 and Arcam 73T?
« Reply #6 on: 28 Sep 2005, 03:43 am »
Hi,
thanks very much.
To throw a monkey wrench in the mix, I'd look at the Cambridge 640. It sounds close to the Arcam, and a couple of hundred less. offten, I see Audio Advisor having demos of black or silver on sale for $419. Just a thought.
Ray
ricmon
« Reply #7 on: 28 Sep 2005, 06:57 pm »
If you get the chance check out the Creek CD 50 MkII.  Unlike the Arcam and Rotel the Creek is upgradeable and it got much better reviews than both.  BTW I have the Creek and I love it.  :wink:
guest1632
  • Guest
« Reply #8 on: 28 Sep 2005, 07:19 pm »
Quote from: ricmon
Hi, The Arcam is upgradable. How much was your Creek?
Ray
Rob Babcock
« Reply #9 on: 29 Sep 2005, 02:59 am »
Better reviews?  Wasn't the Rotel named Product of the Year by TAS?  I don't think I've ever seen a more widely praised product than the Rotel CD player.
I've never heard one, though.
eric the red
« Reply #10 on: 29 Sep 2005, 06:12 am »
Another vote for the Cambridge 640c (which I've owned). A fine cdp and at AA's price and with their 30 day return policy, it's a no-brainer :D .
guest1632
  • Guest
« Reply #11 on: 29 Sep 2005, 06:56 pm »
Quote from: eric the red
Another vote for the Cambridge 640c (which I've owned). A fine cdp and at AA's price and with their 30 day return policy, it's a no-brainer : .
So, what did you replace it with?
Ray
eric the red
« Reply #12 on: 30 Sep 2005, 07:13 am »
My all time favorite cdp the Rega Jupiter. I've owned YBA, Jolida, AH, Rotel, Pioneer and Cambridge Audio cdps plus a Planet 2000 in the last 5 years and always wanted a Jupiter and finally bought one last year. It's a great looking and sounding fun piece of audio gear :D
guest1632
  • Guest
« Reply #13 on: 30 Sep 2005, 08:31 am »
How much is that Rega Jupiter?
Ray
eric the red
« Reply #14 on: 1 Oct 2005, 11:48 am »
Quote from: Ray Bronk
Ray[/quot
You can pick up a used Jupiter off Audiogon for between $750.00 and $900.00 retail is @$1800.00for a new one. It's just a fabulous piece of audio gear IMO
eric the red
« Reply #15 on: 1 Oct 2005, 11:51 am »
Ray
$750.00-$900.00 used off Audiogon-@$1800.00 new. A timeless piece of audio gear IMO and there are very few in that category :D .
