0 Members and 1 Guest are viewing this topic. Read 2514 times.
Kevin,If you're willing, take the $100 prize I won and donate that to the relief effort. I'll be donating other cash as well but every bit helps.Mike
People making donations should make sure to check with their employers about matching donations.I just sold the test cabinets I have and plan on matching that and having my employer match the total. Every little bit helps.Thanks for setting the example.Al
well I can personally tell you they will appreciate anything you can give at this time .. I live in Baton Rouge Louisiana about 40 min from New Orleans and most of the population from NO is here in baton rouge at the time. even though we have lots of places without power at the moment (just got mine turned back on this morning and we have 2 hour waits at the pump for gas) i've donated and will probably go help at a shelter this weekend
