are these worth the money?
0 Members and 1 Guest are viewing this topic. Read 3490 times.
ranmart
« on: 15 Apr 2003, 07:13 am »
I can get a pair of cardas crosslink interconnects terminated with Eichmann Bullet Plugs 1m size  for only $95 Is this a good deal.thanks
Hantra
« Reply #1 on: 15 Apr 2003, 01:56 pm »
Depends on who terminated them.  They could be worthless if the person terminating them didn't know what they were doing.
ranmart
« Reply #2 on: 15 Apr 2003, 07:03 pm »
It was takefiveaudio.com that did them the page is www.takefiveaudio.com/interconnect.htm
jcoat007
« Reply #3 on: 15 Apr 2003, 08:43 pm »
Depends on how they sound and synergize with your system.
I have not heard good things about Cardas cables.  I know that is a broad generalization, but most of the time people comment things like tubby and slow bass, confused mids and rolled off highs.
Those comments usually come after changing to a new/different/better cable.
As Klaus says, synergy rules.  Try it and see.
ranmart
« Reply #4 on: 15 Apr 2003, 08:56 pm »
jcoat007 you sound like you know your cables so in the $100 and under price range what would you recommend. I have a acoustic research pro series oprical cable going from the sacd to the amp now.Thanks
jcoat007
« Reply #5 on: 15 Apr 2003, 10:30 pm »
I am no expert, but what equipment are you using?  You say you have an optical going from your sacd to your amp now, but you were inquiring about analog interconnects.  I'm confused.
Since you are already using the AR Pro Series cable, you might try their interconnect.  Sam Tellig in Stereophile said it was sooo good that it might be all anyone would ever need.  That is not an exact quote, just what I remember from the article.  I think it is also only $20 for a meter pair.
Here is a link to the Pro II Series which is $24.85
http://www.partsexpress.com/pe/showdetl.cfm?&User_ID=12553570&St=3684&St2=-63967584&St3=32667322&DS_ID=3&Product_ID=119213&DID=7
or for $69.80 you can get their high end cable:
http://www.partsexpress.com/pe/showdetl.cfm?&User_ID=12553570&St=3684&St2=-63967584&St3=32667322&DS_ID=3&Product_ID=16127&DID=7
I have not tried them, just a suggestion.
ranmart
« Reply #6 on: 15 Apr 2003, 11:00 pm »
Thanks.What do you like better analog or digital I have never used analog before.Thanks
 some other ones I was think of getting http://www.takefiveaudio.com/ultraconductor_interconnect.htm
byteme
« Reply #7 on: 15 Apr 2003, 11:57 pm »
Ranmart,
Depending on your use, if you're looking at the Ultraconductors I'd also recommend DH Labs silver sonic bl-1.  You can find them very reasonably on audiogon and I know there are a couple people who make them and sell on ebay as well.  They use the DH Labs cable and they terminate them themselves.  I've had both but like my current cables, Zu Warmouth, better than either.
Here's the link for the DH Labs. - http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3017985875&category=14965
markC
« Reply #8 on: 16 Apr 2003, 01:59 am »
Ranmart, have you thuoght of building your own ic's? I built 2 pair of Chris V's fine silvers' and like them just fine. Really sparkle without being bright on my rig. I'm just across the 401 from you, north of To. My cost was about C$100 per pair. You can get everything you need except the wire at Take Five. Have a look in my gallery if you want to see these ic's.
TheChairGuy
« Reply #9 on: 16 Apr 2003, 02:43 am »
Ranmart,
Because they are trusted name you can probably not lose too much if they don't work well and you need to sell them used. Something to be said for trying relatively inexpensive wire (or gear or whatever) first before you move up the ladder.
Hope it works for ya' - changing out wire all the time is a P-I-A.
ranmart
« Reply #10 on: 16 Apr 2003, 02:49 am »
markc they look good.Is there a page that tells how to build them or maybe you can tell me what I need etc.Thanks
markC
« Reply #11 on: 16 Apr 2003, 03:11 am »
Here's a link. It will tell you how to build them and where to get the wire.http://www.venhaus1.com/diysilverinterconnects.html I am not aware of a Canadian supplier for the wire, perhaps someone else can help in this matter. But, as I said everything else you can get from Take Five.
ranmart
« Reply #12 on: 16 Apr 2003, 04:40 am »
I was just looking at my speaker cables and think maybe I should upgrade them first.Hers what I have strightwire duo 6feet with AR pins bi-wired in to the amp.there is only one set of jacks so the 2 sets of wires are locked in to one pin.Would better speaked cable be better then a better audio cable?Is bi-wired in to 2 jacks not 4 better then just one set of cables.Thanks
would this combo be any good for speaker cables
http://www.takefiveaudio.com/belden_89259.htm
http://www.takefiveaudio.com/cable_sleeve.htm
http://www.takefiveaudio.com/cardas_cndp.htm
http://www.takefiveaudio.com/wbt-0644_locking_banana_plug.htm
markC
« Reply #13 on: 16 Apr 2003, 08:45 pm »
Ranmart; I have a 7 ft. pair of Kimber 4tc that I just cut off my 17ft. pair that I would be willing to let go. They are bare, so you could either terminate them yourself or leave them bare. PM me if you are interested. This is a bi-wire pair. (4-7ft. lengths).
ranmart
« Reply #14 on: 17 Apr 2003, 12:54 am »
markc I just bought catcable silvercats with bullit plugs but should have more money in 30 days whitch I will spend on speaker cables.I was looking on tntaudio.com and thay say kimber kable and other hign end cables are no good so I think I will build my own I have not  seen any high end speaker cables with pins on them.
markC
« Reply #15 on: 17 Apr 2003, 02:02 am »
Although there are far better cables, (get your wallet out), and certainly diy is in that catagory, don't believe everything that you read. No offence, but you seem fairly new to this crazy hobby, so if I were you, I'd do alot of research on a product before I laid out the cash. That's what makes this site and others like it so valuable.
Ferdi
« Reply #16 on: 17 Apr 2003, 06:45 am »
I have to agree with Markc, build your knowledge a bit (asking on AC is good) before spending major money. I have found that making your own cables is a cheap way to deepen your understanding of what different materials and geometries can do but also (and more importantly) develop your experience in what to listen for.
