Sync link?
0 Members and 1 Guest are viewing this topic. Read 2627 times.
caleb
Sync link?
« on: 16 Aug 2005, 03:06 pm »
I have the TAG McLaren AV32DP processor with BRYSTON 7B SST amps for the fron two channels.
I noticve that the Brystons have an input to switch on the amps out of standby.
My TAG also has the same looking output (it's like a network connection).
Will the TAG unit be able to switch on my Brystons??
Phil A
Re: Sync link?
« Reply #1 on: 16 Aug 2005, 06:40 pm »
Quote from: caleb
If it is a DC trigger (vs. perhaps the PHAST link) you should be able to get it work.  My SP1.7 connects to a 14BSST which connects to a 6BSST and then to my Rotel DVD-A player.  The Rotel has a mini-jack connection (vs. bare wire like the Brystons) and I just hooked the 6BSST to it using the proper connector.
caleb
Sync link?
« Reply #2 on: 18 Aug 2005, 07:40 am »
Thanks - trouble is - I don't know exactly what the TAG sync link is giving out.
If it is a voltage more than 4 volts, it will of course be able to turn on the 7B SST through the input connector supplied.
Oh dear - how to find wht's happening! ! !
gravy
  • -Scott
Sync link?
« Reply #3 on: 18 Aug 2005, 02:17 pm »
Quote from: caleb
Hi Caleb,
Do you have a voltmeter or micrometer that you could use to test the output voltage?
Phil A
Sync link?
« Reply #4 on: 18 Aug 2005, 08:46 pm »
This thread describes a different purpose for the sync link vs. a DC trigger:
http://archive.avsforum.com/avs-vb/history/topic/150691-1.html
Sebastiaan de Vries
    • http://www.soundevolution.nl
Sync link?
« Reply #5 on: 12 Sep 2005, 09:35 pm »
Dear,
Tag's "sync link" is a voltage to control a VCXO in a Tag cd transport. Not wise to connect that to a DC trigger ;)
If you want to turn on bryston amplifier you can search inside the Tag for a constand DC voltage between 4 and 12 volt. Feed this to the amp and voila. Make sure the standby switch switch of this voltage to.
With kind regards,
Bas
