3BSST Sensitivity Setting
0 Members and 1 Guest are viewing this topic. Read 1731 times.
elcaptain88
« on: 11 Aug 2005, 10:02 pm »
I'm auditioning a 3BSST and am uncertain of the optimal sensitivity setting for the amplifier - 1V or 2V. I will be using a Van Alstine T7 preamplifier w/ single ended RCAs - any input on the proper setting or how this affects system interaction is much appreciated.
avahifi
    • http://www.avahifi.com
« Reply #1 on: 11 Aug 2005, 11:09 pm »
All other things being equal, I would suggest the 2V setting as that will provide more useful rotation of the preamp's volume control and lower overall system noise.
Frank Van Alstine
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 12 Aug 2005, 12:59 am »
Frank - I just realized it was you.
I want you to know my first hi fidelity preamp was your Model 1 back in the days when Star Television in Toronto was your distributor.
In fact I was the Van Alstine rep for Canada for a while.
james
BachToRock
« Reply #3 on: 21 Aug 2005, 09:03 pm »
Quote from: avahifi
Frank Van Alstine
Will the S/N really be better at the 2V setting?
« Reply #4 on: 21 Aug 2005, 10:27 pm »
Yes by about 3dB.
james
