JVC RX-D301/302 DVD-multi inputs
0 Members and 1 Guest are viewing this topic. Read 1473 times.
soundboy
    • My simple Yahoo 360 webpage
« on: 5 Aug 2005, 07:03 pm »
I was just looking over at the owner's manual to these receivers and I noticed no DSP or any other digital manipulations can be applied to the multi-channel analog inputs.  Does this mean that these inputs doesn't get digitalized?
Feisal K
    • DVD-A registry
« Reply #1 on: 6 Aug 2005, 02:30 pm »
I don't think they do.
Higher-end AVRs or pre/pros have a ADC stage there - that allows you to do bass management and other DSP manipulations on the analog inputs; most AVRs just pass the signal directly to the (analog) amplifier.
I believe in the case of digital amps, the analog audio signal is used directly to modulate the PWM carrier signal (which drives the output devices)
tschanrm
« Reply #2 on: 8 Aug 2005, 07:51 pm »
Yes.  That should be a good thing though, as you can have a direct analog signal be routed to the amp via the 5.1 input:  5.1 input-->AMP.  Connecting analog to any other input will cause the receiver to do: Analog-->ADC-->DSP-->DAC--AMP.  Hope this helps.
soundboy
« Reply #3 on: 8 Aug 2005, 09:18 pm »
Thanks for the explaination, Feisal K and tschanrm.
I am interested in the JVC but now I am concerned about the heat issue.  I suppose that's another thread.
