0 Members and 1 Guest are viewing this topic. Read 4925 times.
..... (about the Nuforce ampflifiers I recently tried)... To me, they sounded warm and buttery WITH digital room correction (also known as DRC) provided by the TacT preamp I'm demo'ing. Without the DRC, I found them lacking in some ways, having a little bit darker and sterile sound to them. But, I wouldn't call them dark and sterile, just that in comparison to having DRC enabled, they leaned in that direction. However, I could say something equally negative about every amp I compared last weekend... that without DRC, the amp had a grainy upper midrange, or boomy bass... or whatever... but WITH the correction, any of the 4 amps I heard would be great (and the decision was based on the personality of each amp setup and not the room's reaction to each amp). It just seems as if I've been chasing my tail a long time trying different amps to get the right sound. However, all along I realize now I've mostly been hearing my room reacting to what the amps did. When you take the room out of the equation (or consistently fix it), the sound is GREAT no matter what you do. I wish you lived closer so I could bring this stuff over to your place and show you what I'm experiencing every day. The difference is minor at first but it grows on you... Much like the first time you hear a pair of Europa's... it's like it soaks in after a while that what you're hearing is very realistic... and not overly hyped. However, the beauty of this correction stuff is the adjustments. It's like having a really sophisticated lossless equalizer as well... so, you can bump certain areas a little more or less to get what you want. I'm amazed at the sound in my room on a daily basis. I hope you can one day experience what it can do IN YOUR ROOM... Especially since yours is as small as mine... The correction just makes all the music so much more cohesive, instrument separation is for real, palpability is improved, etc... It's just so awesome. I rarely gloat about something so much but I would think the TacT plus a good amp (or 2) would get you closer to sonic nirvana than you ever thought possible. It has done this with me. I absolutely cannot live without it now. Going back to my DK w/ no correction just won't do anymore. Anyway, just thought I'd relay how ecstatic I am about the TacT gear. It's everything I've ever hoped for. If you have a chance to experiment with it, let me know. I'll be glad to help where I can.
I have noticed there is a compromise... and I can't put my finger on it but it's in the sound quality itself... not what the sound does, like imaging, separation, etc... but the actual sounds aren't as transparent as I think they could be. I'm guessing that's what the power supply upgrade addresses. I'll be trying that soon after getting the new amp.
So what does your setup look like now? Are you using TACT 2.0 or 2.2 with TACT's DA converter instead of your Delta soundcard's DA?I"m sure the new PS does wonders for TACT, but what I noticed even doing minimal digital processing in PC software is a subtle "something." It 'could' be called loss of transparency, but to me it's more like 'freshness' of instrumental life playing in front of me. Reminds me of fresh-brewed mountain-grown coffee that's an hour too old.. I'm rethinking my plans for PC-based DRC and/or TACT/DEQX DRC for now until this field matures a bit more for less $.
But the TACT isn't a cure all -- if you have modal ringing, the TACT cannot cure this. Only acoustic treatments can "cure" modal ringing.
In the future I will try a "Double Bass Array" setup..
Hearing bass notes in your room one hertz at a time is very enlightening -- you can have +15dB and -15dB at two nearby frequencies, which would average to 0dB with most test CDs and meters!
Eric, can you explain what you mean by this? Since you already have 2 bass towers I assume it's different.Thanks
After I wrote my initial impressions, I thought about 'BrunoB'... the master of foam... icon_wink.gif He did an experiment he called the 'foam cocoon' that essentially removed the room from his musical presentation. The TacT does something similar to that. I wish I could have Bruno drop by and hear this, with a specific cd he used of a violin solo, and see if he liked it. I bet he would. But, he's back in Belgium now so, 'dropping by' isn't an option... A lot of the things I heard in his cocoon, I could hear after the correction was done. It just removes the walls and makes your experience much more real. ...
