0 Members and 1 Guest are viewing this topic. Read 22122 times.
Just thought of another interesting thing about my room/set up. The 10" woofs of the RM30s fire toward each other, which run full range, for whatever that is worth.
Youngho,It's not the listener to sub distance that is important with the out of phase, dipole setup. It is the DIFFERENCE in distance from the listener to the in phase and out of phase subs that is key, however, that is complicated further once you get off axis because there are 4 subs involved. If his subs were all equally distant from the wall, then a central listening position would have almost zero SPL from the subs with them wired out of phase. Dipole takes the irregularities in room shape out of the equation to a great extent.
Oh and to be sure, I never called "MY" Push/Pull set up a dipole.
I agree with you that calling it a dipole when you are listening between the poles probably isn't an accurate term, however, I do believe many of the same principles apply especially with regard to room interaction...The bottom line is that using an equal number of in phase and out of phase subs puts zero net acoustic acoustic energy into the room.
Yes, you're right. I've even forgotten what point I was trying to make.
