0 Members and 1 Guest are viewing this topic. Read 22124 times.
I'm doing something similar, but with one sub at the front and one at the seating position. I'll deal with my room mode at 28hz with the XO because the subs will have 28hz as the upper cutoff. My primary emphasis is to keep output in room because I watch late night movies, so I'm pretty sure that changing things in the time domain will mess me up. If I start equal but opposite phase waves at the same time, my net in room is 0, which should drastically reduce what tries to escape. If I set the waves off ...
The graphs presented in that German paper still don't make sense to me. Look at the average SPL of sub-23Hz bass relative to supra-23Hz bass in graph 1, then again for graph 2. As we all know, modes represent standing waves, which essentially represents a phenomena of constructive and destructive interference related to wavelength and room boundaries. If measurements are taken in or near an antinode, then cancellation of the mode should result in lower SPL (i.e. the peak goes away). The average SPL of supra ...
... what still remain are the natural frequencies resonanting in the longitudinal dimension, which usually have the strongest and most harmful influence on bass rendition. As a counter measure, generous acoustic absorbers can be used and/or and a second identical bass array (DBA = double bass array) can be added at the back of the room. These extra subwoofers are driven with a delay corresponding to the travel time in the longitudinal dimension and with reversed polarity. The rear array thereby works as a kind active acoustic sump and eliminates the influence of the natural resonances in the longitudinal dimension...
Here is a Q&D (quick and dirty) drawing of my set up, which is not to scale.I haven't taken it to the exact "mirror image" stage yet, for practical reasons (I wanted to keep the front subs in the same plane as the RM30s)However, the front and rear subs are "exactly" (as of yesterday) equidistant from the listeners ear.The improvement was a gradient increase in "detail and texture" to the bass. This was by no means missing before, but it did offer a noticable improvement.I would suspect even ...
Thanks for the diagram, a picture is worth 1,000 words!It seems the main effect of your current setup is cancellation of the primary waves (coming from the fronts of the subs towards the listening position). This will occur most efficiently at the equistant line between the front and rear subs, i.e. your listening position. It should be effective in keeping the sub primary wave from hitting the walls and bouncing back into the room. .
Most of the bass you are hearing at the listening position is likely from secondary reflected waves off the walls, floor, and ceiling which will sum in an unpredictable pattern -- this occurs because the frequencies produced by the subwoofers are omnidirectional no matter which way the drivers are oriented. I would expect moving the listening position forward or backward from your current location would significantly change bass quality/quantity, and of course separate the temporal arrivals from the front and rear subs.
Adding progressive delay to the rear subs would shift the line of maximum cancellation behind the listening position towards the rear wall. If pushed all the way to the rear wall this should prevent reflections off the rear wall from returning into the room to create interference peaks and nulls. It should also result in consistent, temporally correct bass throughout the room, as what will heard by the listener is mainly the undisturbed primary wave arriving from the front subwoofers.
It is interesting that by adding or not adding delay to the rear subwoofers may completely change what is heard at the sweet spot -- secondary reflections (no delay) or primary wave (with delay) . I wish I had four subs now! John since you already have the four subs, if you ever see a good deal on a device which could add delay to your rears, maybe a pro item, it would be fun to play around with it. Certainly I'd be interested in knowing how these two setups compare with music signal.
|--------------|| s1 || || || chair || || || s2 ||--------------|
I have 2 subs (both VMPS Largers) and tested John's "push/pull" theory using the room correction software on my Meridian (provides a graphical interface w/ frequency sweep, waterfall and impulse response graphs).I have on sub on the front wall, about 3 feet in from the corner, and the other sub on the rear wall, about 3 feet in from the other corner:
John,I am confused on the polarity/phase issue. Maybe you can educate me... ...
If you have two subs at the same distance from a particularly point in space (such as the listening position) and the output of one sub is inverted in phase relative to the other, why would their outputs not cancel at that point ? It shouldn't matter whether the two subs are right next to each other or on opposite ends of the room. You seem to imply that in your current arrangement the outputs of the front and rear subs sum, rather than cancel, at the equidistant listening position. This is what I would expect with the front and rear subs wired with the same polarity, not with inverted polarity.
Obviously if the distances are not equal between the front and rear subs, cancellation or summation will occur at varying degrees at different frequencies, depending on location.
I'm not trying to be confrontational in the least, and I'm sure your system sound fantastic. Rather I find real world room bass acoustics fascinating and challenging, and am trying to learn as much about it as possible.
John & JGubman,Now you guys have me confused. Are you both saying that you have subs that are equi-distant from your listening position firing out of phase, at the same time or with the rear subs on a time delay?If they are firing at the same time and out of phase, I don't understand why you aren't getting a dipole null effect at the seating position. What is the sound like at the perimeters of the room?
If the subs are equal distances from the listener, and "IN PHASE" they are both moving toward the listener in unison. That is as the front subs woofer cone moves towards the listener, the rear subs woffer cone moves toward the listener. This means the wave enregy is "launched" toward each outher and will arrive at the listener at the same time. The collide at the listener and their sonic force being equal will effectively "neutralize" the other. If the subs are wired "out of phase", then as the front woofer moves toward the listener, the rear woofer moves away from the listener and the summed effect is that the it creates the greatest movement of air, because the woofers work in unison, to move the air in the center of the room between the two Subs.
