0 Members and 1 Guest are viewing this topic. Read 22123 times.
That is my thinking too. I've always thought that 1. Equal distance + equal phase = summation of response = increased amplitude 2. Equal distance + opposite phase = cancellation of response = decreased amplitude This certainly is the case with two front subwoofers only. I obtained this graph by measuring my two front subs, one at a time, from the listening position, one with positive and one with inverted polarity (by switching speaker wires on the in phase and one out of phase (speaker wires swapped on right channel only). Listening with this setup with Ethan's Realtraps test tones and with music, it was very obvious that there was a marked reduction in SPL at the listening position compared with both subs wired with the same polarity, or even just one sub by itself -- confirming that cancellation was indeed occuring. This is analogous to what happens at the sides of dipole bass radiators. :
As the front woofer pushes, the rear woofer pulls. That wouldn't nullify the bass, it would make it more efficient. ...
Quote from: John CaslerAs the front woofer pushes, the rear woofer pulls. That wouldn't nullify the bass, it would make it more efficient. ...No, it would! Wavelengths much longer than the size of the head will always arrive unattenuated and 180 degrees out-of phase at either ear and therefore will always largely cancel. What you still hear is largely stray room reflections.
The sound wave leaves the sub, passes the listener (where it is heard) then crashes into the rear wall, and bounces back at the rear of the listener. Now when it reaches the listener and the waves coming from the front sub what happens? It collides with these waves. Does this collision cancel? or does this collision amplify? It cancels.
Reducing the pressurization of the rear wall, by having a woofer fire "in unison" (out of phase so woofs move in the same direction in relationshipt to each other) with the front brings us closer to having no rear wall.
If you have a "SINGLE" sub playing on the middle of the front wall what happens? The sound wave leaves the sub, passes the listener (where it is heard) then crashes into the rear wall, and bounces back at the rear of the listener. Now when it reaches the listener and the waves coming from the front sub what happens? It collides with these waves. Does this collision cancel? or does this collision amplify? It cancels. So the wave continues on to the front wall, and again bounces off toward the listener. As it passes the Sub, it "joins" what ever is coming from the sub and then makes it to the listener. Now does this "joining" or "summing" cancel? or does it amplify? It amplifys.
Quote from: cseroQuote from: John CaslerAs the front woofer pushes, the rear woofer pulls. That wouldn't nullify the bass, it would make it more efficient. ...No, it would! Wavelengths much longer than the size of the head will always arrive unattenuated and 180 degrees out-of phase at either ear and therefore will always largely cancel. What you still hear is largely stray room reflections.Hi Frank,How does that relate to having the rear pair of SUBS "out of phase" or "in phase"?Are you saying it doesn't matter which?
Thanks John,Bass going into the bedroom with the rear subs off was just as I had hoped, louder with the rear subs OFF.I'm having a hard time wrapping my brain around your in room results being so comparable in phase and out of phase. Are you using identical subs and amps with all set to the same output level ?I think I'm going to breakdown and build some test boxes first.
I don't think that John Casler's results are that surprising, considering that the acoustics of his room are significantly more complex than a rectangular room would predict, due to the differences in wall construction, openings, and diagonal front corner. One might predict a significant cancellation at the frequency (and multiples thereof) whose wavelength corresponds to the distance from the listener to the subwoofer, but this is probably be high enough that the loudspeakers are also (or may be solely responsible) for reproducing this frequency, as it seems relatively unlikely that the subwoofers are more than 14 feet away from the listener. ...
Look at this dipole illustration: http://www.hometheaterhifi.com/volume_2_4/dipl1.html Am I hearing some saying that the sound "inside" of, and between, the illustrations drivers would be less than inside the next bipole illustration. http://www.hometheaterhifi.com/volume_2_4/bipl1.html That would be interesting physics, but stranger things happen.
That's what I think. In the dipole box, as the one driver moves in and the other out, the volume of air inside the box doesn't change. And the rear waves of each driver would largely cancel themselves out. Microphone inside the box would record lower amplitude...
