Best platform for turntable, not wall suspended type
0 Members and 1 Guest are viewing this topic. Read 2589 times.
Bemopti123
Having gotten my vinyl gear in place, I am interested in getting a turntable platform or stand.  Something that is non suspended, because I do not own the walls of the apartment I live in.
Is there a DIY type of stand where I can put my turntable in?  The far right now is that I am running out of top shelf space.  I have a large amplifier in one, have 3 components that need to have free space above them, preamps and amplification that have the control on type, typical hi end Japanese stuff, as well as a top loaded CD transport, now, a turntable.
What gives?  I saw someone with a IKEA kitchen cart with butcher block platform.  Did not look big or anything.  Any ideas of the platform and or stand where I can place some items?
I do not want to break the bank.  Please recommend something cool and decent sounding.
Paul
Marbles
« Reply #1 on: 19 Jul 2005, 11:35 pm »
I would talk to solidwood about a table, and then I would get Robert Schults' (Ridge Street Audio's) ideas on how to insulate the turntable from vibration.
I saw a turntable that he has that used silicon filled pillar posts to dampen the vibrations.  This "booby table" looked really cool and effective.
mcrespo71
« Reply #2 on: 20 Jul 2005, 12:45 am »
Ikea Lack is a cheap solution for a TT stand.  Ask audioslave- he uses one on his TT.
Michael
toobluvr
« Reply #3 on: 20 Jul 2005, 03:24 pm »
Check my gallery and see what I use.  If your decor supports the industrial look, and you are "ugly tolerant", you might wanna consider it.
Not exactly eye-candy, but I can tell you that when I moved my vinyl rig to this from its former location (a rigid and heavy DIY 5 shelf MDF stand), the sonic improvement was staggering.  So much so that,  despite the lack of visual appeal, I am unwilling to change.  Aesthetics can easily be improved w a coat of black (or burgundy, or whatever)  Rustoleum paint.   Price for the whole thing was under $200 shipped.
I have read all the controversy about granite and ringing.  I have yet to experience it.   It has done nothing but good things to my system.  Are there stands out  there that will "sound better"?  Probably.  I don't spend an awful lot of time a/b'ing equipment stands.  I do know that I don't hear any nasties, nor anything at all,  that makes me think a change is needed.
Depending on your table, your needs may be different.  Conventional wisdom holds that non-sprung tables (mine)  need mass + rigidity, while sprung tables benefit best from something rigid but light.
Perhaps if you provide details of your setup, more useful input can be provided.
