0 Members and 1 Guest are viewing this topic. Read 1573 times.
Otis
« on: 16 Jun 2005, 09:01 pm »
« Last Edit: 2 Feb 2011, 07:50 pm by Otis »
avahifi
    • http://www.avahifi.com
Will the U70 drive four speakers?
« Reply #1 on: 17 Jun 2005, 12:19 pm »
Can you tell me the impedance and sensitivity of your speakers and perhaps a description of the wiring hookup?  I suspect the U70 will work just fine if you use the 4 ohm speaker taps.
Frank Van Alstine
avahifi
« Reply #2 on: 18 Jun 2005, 02:25 pm »
The Ultimate 70 should work just fine with the speakers and wiring arrangement you describe.
Frank
