0 Members and 1 Guest are viewing this topic. Read 5822 times.
Are you running the 626R's full range, or are you high-passing the bass? ANY ported speaker is going to have serious problems if you play loud bass at below it's resonance point. For the 626R's, that means if you play loud bass below 40hz, it will cause the woofers problems. Only solution is to high-pass them, or get a speaker with a lower tuning and greater overall output capability.
So what do you guys feel will be the best solution for me at this point? I am not adverse to going to seperates if that will help, though the prospect seems rather exspensive unfortunately.
George hit the nail on the head and at no cost to you:"Also, can you put the sub between the speakers? " Or you could get another sub and put the 626's on top, that of course would be more money. If you're driving the sub and the 626's with that little receiver I'd be surprised if you didn't run out of power very fast especially if you have been playing with much volume at all. Clipping will make bass sound loose and mushy btw.
First try the Panny with the high pass crossover.See if that takes care of your problem.You can then look into a passive high pass filter for the 626Rs.You could also spend a LOT of money and get into separates with a DAC, preamp, electronic crossover, and power amp.I believe some of the TACT preamps have a crossover built into them and they will keep the signal digital. They will also provide room and speaker correction.
Darayan is more than welcome to buy my other Larger sub.
If the x-over is actually 100Hz (I'm not familiar with that unit) you will probably need to place the LARGER exactly between the speakers in order not to get a "pull" towards the sub. If it is not in the center when crossed that high, male voices will will be pulled toward the sub.
