New! DigitalAnalogueDIY.com - UcD 400 Amp Group buy project
0 Members and 1 Guest are viewing this topic. Read 22301 times.
Regnad
« Reply #80 on: 1 Sep 2005, 05:41 am »
I bought the E100 case drilled for a power amp.  The rear layout, however, is symmetrical and not like the E130 photo.
Thanks for the balanced input help.  I should have looked a bit longer.
The speaker post holes are definitely too small.  The inner stepped keyed section of the isolator that goes on the outside of the case will not seat in the hole.  I will try to post a picture.  Should I use the Gallery to do that?
Thanks.
angelo
« Reply #81 on: 1 Sep 2005, 07:09 pm »
mounting the amp modules at the back of the of the chassis is the best way to minimize wire lengths.
i'm looking at softstart circuit to add on this project, there are a lot designs at diyaudio but most of them needs a PCB, maybe somebody here have knowledge of PCB printing or someone can make a template and have them printed, KEN, do you think you can organize something for a softstart circuit?
thanks,
angelo
carlos spud
    • http://www.steamlineaudio.com
amps lab has a soft start
« Reply #82 on: 1 Sep 2005, 08:44 pm »
looks like amps lab has a good one
ken_diyzone.net
    • http://www.DigitalAnalogueDIY.com
« Reply #83 on: 12 Sep 2005, 08:50 pm »
Hi,
These are the items I have left from the UcD400 GB, please let me know if you wish to buy them.
Hypex HG PS -- 2 pcs at $210 per.
Transformer for UcD400 -- 4 pcs at $60 per.
UcD180AD -- 6 pcs at $112 per.
Hypex Standard PS -- 3 pcs at $100 per.
I will throw in 6 sets of the Hypex wires if you buy the 6*UcD180 and 3*Standard PS together.
