FS: PranaFidelity Fifty90 Loudspeakers
Ishcabible and 1 Guest are viewing this topic. Read 101 times.
rockadanny
« on: 22 Dec 2025, 04:20 pm »
A stunning, gorgeous, used but near mint pair of PranaFidelity Fifty90 speakers — highly regarded, superbly hand-built audiophile monitors with excellent coherence, natural timbre, and musical dynamics. These stand-mount speakers punch well above their size, delivering expansive soundstage, detailed midrange, and articulate bass for serious stereo listening. No sub necessary for music. Perfect for 2-channel music or as fronts for a high-end HT system. Made in the USA.
Stands included (as shown in photos)!
Speaker Technical Specifications:
Type: 2-way symmetrical array loudspeaker, front ported for easy placement
Finish: Piano Black
Drivers: Dual 15 cm woofers + 30 mm tweeter
Frequency Response: ~39 Hz – 22 kHz (in-room)
Rear Toggle Switches: HF and midrange adjustments for easier room and system integration
Impedance: 8 Ω nominal
Sensitivity: ~89.5 dB (2.83 V @ 1 m)
Recommended Amplifier: 20 W+ @ 8 Ω
Dimensions: 22" H x 9.5" W x 15" D
40 lbs each
Grills magnetic attach.
Stands: Steel, 24" tall, tri-post, black, mass-filled to control vibrations, new retail was over $150.
Pickup only (30064) – No shipping. Cash only.
INFO regarding the REAR TOGGLE SWITCHES on each speaker ...
They help with component matching and system integration, specifically, high frequency extension and the midrange character.
The top switch has two positions for the high frequencies:
The “down” position selects a natural balance for the high frequencies (a gradual, -2 dB roll-off from 12
kHz to 20 kHz), and the “up” position removes much of this -2 dB roll-off for a near flat response to 20kHz.
The bottom switch targets the character of the midrange through three positions:
Down = default (neutral/natural),
Middle = presence (the midrange moves perceptibly forward several inches)
Up = warm
Includes:
Original speaker shipping boxes, user manual, stands (no boxes).
newzooreview
Re: FS: PranaFidelity Fifty90 Loudspeakers
« Reply #1 on: 22 Dec 2025, 04:44 pm »
Apologies if I've overlooked it, but what price are you asking?
