0 Members and 1 Guest are viewing this topic. Read 3076 times.
Is it possible to make the baffles with 80 degrees angle instead of 90 degrees? The reason is I want to make the sub a little lower.
Yes I know about the W frame. The question was if I can make the upper and lower baffle with 80 degrees instead og 90 degrees, so the subwoofer itself becomes lower.
Do you have more detailed plans than at your website? Because then I want it
