BDP3 poweron status
0 Members and 1 Guest are viewing this topic. Read 5987 times.
michelmassot
BDP3 poweron status
« on: 29 Aug 2025, 09:36 am »
Hello,
the BDP3 defaults to MDP at power on. I have to select DNLA Renderer every time if I want to use this setting. Is it possible to have DNLA Renderer as the default? Maybe with a startup script?
Thank you for your answers.
  • The Demo is Everything!
    • http://www.bryston.com
Re: BDP3 poweron status
« Reply #1 on: 29 Aug 2025, 10:05 am »
Hi - email Chris on this please - [email protected]
gbaby
« Reply #2 on: 29 Aug 2025, 06:48 pm »
Hello,
Just for information, what does DNLA allow? I only use MPD to play local files and the radiio. Tnanks.
gbaby
« Reply #3 on: 29 Aug 2025, 08:08 pm »
On second thoughts, never mind as I read on it and will not be using it.
michelmassot
« Reply #4 on: 30 Aug 2025, 08:02 am »
Thanks James, I'll email to Chris.
GGaby: it's because I mainly use Qobuz, and MM is not friendly for that. I own very little music locally. And also good french radios are not available on bRadio (FIP and others RadioFrance radios). So, as many others, I'm waiting for MM renewal and/or QobuzConnect on Bryston units. Roon could be an  alternative, but it's expensive and... american ;)
gbaby
« Reply #5 on: 1 Sep 2025, 01:07 am »
... and... american ;)
I'm feeling you. 8)
michelmassot
« Reply #6 on: 7 Nov 2025, 05:00 pm »
Hello, it's been two months since I emailed Chris. Twice! I also submitted a request on the Bryston website: I haven't received a single response!!! The MM interface is awfull for Qobuz. I've read that many people complain about MM. I'm surprised that no one at Bryston is responding to them. I recently bought some Bryston equipment (second-hand) and I regret it!
galyons
« Reply #7 on: 7 Nov 2025, 08:51 pm »
Bryston makes great equipment.  They are great at supporting the hardware. Given the debacle with the MM/OS3 user interface, that has been negative press for over three years, they obviously are not great on the software side.  Sadly Bryston is making a bad situation worse by ignoring the multi year old digital user interface issues and the stream of failed promises. Best practices, in customer communication, is to over communicate and "'fess up" quickly when things go south.  Just ignoring the customer concerns means the problem continually remains as negative press out in the customer, and potential customer,  base.
Negative press damages the corporate image and costs sales. Again. good corporate communications protocol is to close the issue by clearly sharing the actual status of the user interface situation.  Set a firm new digital customer interface delivery date and hire resources capable of getting it done correctly, or admit that OS3 will never happen and customers will have to live with MM, and its limitations. That simple, fact based communication should stem the slow leak of user faith in Bryston and their lines of product. It is well past time for Bryston to step up and address the issue.
Twiga
« Reply #8 on: 8 Nov 2025, 08:00 pm »
I agree 100% with your comments. I think that this item should also be posted on the Bryston “Digital Future” forum.
